Home > Wheels & Tyres > Sankey tyres |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3690 |
Have a play here and see what gets you closest.
https://www.tyremen.co.uk/tyre-size-calculator |
13th Nov 2019 6:08am |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 524 |
235/85/16 are recognised as a direct replacement for 7.50’s and almost the same diameter
13th Nov 2019 6:41am |
They're a lot bigger than the 6.50's that the OP talks about though Darren
13th Nov 2019 7:57am |
In terms of diameter, a 235/70 is the closest. They'd be ok on Wolf rims but not on original Sankey steel wheels as they'd be too narrow. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
13th Nov 2019 8:01am |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3795 |
Hello
I use the same as on my truck, that way I have a spare when towing Same make / size 235/85/16 conti's Click image to enlarge |
13th Nov 2019 8:14am |
Perfect choice that’s why I recommended them as above ^^^ assuming the OP is on OE 235/85’s - most newer Ex Mod LR trailers Penman / Sankey type are also fitted with this size for that reason
13th Nov 2019 3:59pm |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 923 |
I run my Narrow track on 205R16's and they didn't make any difference to towing height when fitted to replace the old 6.50's Used the original military rims too. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
13th Nov 2019 6:54pm |
Avelingporter Member Since: 25 Jan 2016 Location: Southampton Posts: 406 |
Thanks LRA and DR. Sounds like you are closest. Yes they are 6.5 on the small rims. It’s a mk2 trailer I think. Wider but still on drum brakes.
13th Nov 2019 10:14pm |
