Home > In Car Electronics > Battery Charger connector
Page 1 of 4 1234>
mark13
United Kingdom 2004 Defender 90 2.5 TD HT Cairns Blue
I’m in a tinkering mood, I have a CTEK battery charger/conditioner on my Defender as I don’t use it often enough 😞
Currently I have the charger cables coming out under the seat, so looks crap, I am thinking of putting a panel mount connection, so I can just jack straight into it with the charger. Can anybody recommend what type of connector to panel mount. Please don’t say cigar lighter, they are my pet hate, the choice I have available seem endless!
Post #801937 12th Nov 2019 2:55pm
How about a Hella socket? Much more robust than a cig. lighter one and rated at 10amps. With an appropriate fuse in line, could also double as a permanent live power point. Darren
Post #801947 12th Nov 2019 4:13pm
grafty99
I use a CTEK maintainer on my motorbike (which has a factory fitted hella socket by the ignition barrel) and it works great.
I used the supplied battery fly leads, cut off the ring terminals and wired it into a hella plug. As LRA suggests, much stronger than the CTEK connector and useful for other things (tyre pump in my case) Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #802021 13th Nov 2019 12:32am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
If you go with the CTEK plug: their "comfort indicator panel" snaps into a Carling switch bezel, which might look good if you have some Carlings.
Post #802059 13th Nov 2019 11:48am
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
yep as above, get the CTEK panel - can be had for less than£20
Or you could get the 13 pin towing socket adaptor from Martin of this forum.
Post #802068 13th Nov 2019 1:27pm
Martin
Site Admin
https://www.defender2.net/shop/tow-electri...c-p45.html
Whistle  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #802116 13th Nov 2019 6:26pm
mark13
No I’m stuck, I ordered a panel mount Ctek adapter (I had never seen them before) but then saw the 13 pin towering socket cable reply which I do like the idea of...... hmm the choices, I’m a bloke I don’t do choices!
Post #802187 14th Nov 2019 5:53am
seriesonenut
This thread is good timing for me as I am assembling a few ctek bits to do something similar. I now have the dash mount connector but I intend to fit it to the outside of my 110. Reason, I do not want a cable through the door. I have the 'trailing' socket fitted to my series one which just tucks behind the grill and seems waterproof. Looking at the dash mount I have seen examples on boats motorbikes and quad bikes so Im sure its going to be ok. Que drill this weekend....... 1984 One-Ten CSW
2010 XS USW (sold)
1957 Series One 88 diesel
1958 Series One 88 4x2
Post #802199 14th Nov 2019 7:57am
discomog
I use the 13 pin tow plug as suggested by Martin. I originally toyed with the idea of fitting a Ctek panel but didn't like the thought of cutting a hole somewhere in my Defender. (there's enough corrosion inherited from Lode Lane without me adding to it Rolling with laughter ) Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #802202 14th Nov 2019 8:35am
kmac
I did mention Martin's socket in my post....however, for that you work you must have a 13 pin towing socket or a 7 pin with battery connection (12S) - the older 7 pin (12N) sockets do not connect to the battery.
Post #802268 14th Nov 2019 7:51pm
ericvv
If like me you have the 7 pin 12N towing socket installed, easy to add the 12S to the truck. The genuine from Land Rover is very good quality. Easiest option to connect the Ctek, no need to even unlock the truck.
Eric
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #802321 15th Nov 2019 7:57am
Rashers
As I expect has happened to others on here, my Puma chirped as I started it on Saturday.
I really like the idea of one of Martin's adaptors. The 12S Socket looks good. I had a 13 pin on my last Focus and I have to say, I always thought it felt a better connection than the 12N's I had on other vehicles.
My point is, how difficult is it to install the 12S or the 13 pin socket? ericvv has a genuine LR 12S (I like that idea as my truck is just about stock), do LR do 13 pin kits as well?
Also, any recommendations for which Ctec charger for continual charging the truck?
Post #822336 30th Mar 2020 6:09pm
kmac
Re your last question, the CTEK MXS 5.0 should be more than adequate
More powerful ones will charge it faster, but that is not necessarily a good thing.
Post #822364 30th Mar 2020 7:37pm
Rashers
Thanks kmac Thumbs Up
I have seen that Duckworth's do both the Sockets as LR branded. Just interested to know is it a plug and play or is it a bit more involved? I have a 2014 Puma 110 Utility
Post #822370 30th Mar 2020 7:42pm
bear100
I use the plug that cane with mine, handy LEDs on there too.
It just lives under the seat
 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #822372 30th Mar 2020 7:46pm
Page 1 of 4 1234>
