Home > Maintenance & Modifications > Door seals
dioliahary
Door seals
Hi quick question, I am having a mare fitting britpart door seal, it keeps popping off at the front curved area. Tried glue but I am not comfortable with the outcome.
Are OEM seals pre formed, so you do not have to shape them yourself. 1990 200tdi conversion 90
Post #802009 12th Nov 2019 10:22pm
oneten110
No, the standard genuine seals are not preformed other than in the corners at the top of the door. It is not a Defender, it is a One_Ten
Post #802014 12th Nov 2019 11:03pm
bear100
Not the answer your looking for, but genuine is the way to go, yes twice the price but so much better.
Tiger seal would certainly help with the ones you have Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #802016 12th Nov 2019 11:21pm
dioliahary
On the drivers side the seal has a flat face wher it crimps onto the metal edging strip for security.
The seal I am having to fit has a curved face instead of flat. So wher you would tap it on with a soft mallet there is two different faces, one flat on the driver side and one curved...the awkward one. Is that the difference between after market and OEM.
Think Tiger seal is way to go as its drove me crazy 😡 1990 200tdi conversion 90
Post #802017 12th Nov 2019 11:26pm
grafty99
Definitely go with genuine seals, far superior Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #802018 12th Nov 2019 11:27pm
Balvaig
Definitely go genuine. These are not preformed but have a metal insert which grips the door frame and will fit the curved area ( you apply downward pressure whist fitting the curve).
The seals are haded left and right too.
Post #802114 13th Nov 2019 6:21pm
dioliahary
Thanks for the advice👍 1990 200tdi conversion 90
Post #802123 13th Nov 2019 6:55pm
