Home > Puma (Tdci) > Clutch Squeak in a Puma 110
ElDoc
2009 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
Hi there, like to know if someone has feel a constant squeak when the clutch are use, I have that problem in my car and the sound drive me crazy, I try to lubricate the lower spring but the sound is internal in the cylinder, my Defender is a 110 SVX.
Regards, Confused El Doc
Actual
Defender 110 SVX
Past
Defender 90 Tomb Rider 2001
Defender 90 TD5 Black Defender 2002
Post #80191 13th Jul 2011 10:55pm
Bomber82
Italy 2009 Defender 110 Puma 2.4 SW Zermatt Silver
Same problem...and with summer temperature it sounds worst... Crying or Very sad Matteo
Defender 110 Td4 SE MY 09
Post #80747 18th Jul 2011 8:44am
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I had that as well. Warm weather aggravated the issue. Round trip from Oxfordshire to Romania was somewhat less than enjoyable due to the constant squeaking.
I had two squeaks... one internally, and one on the actual pedal itself.
During the 24K service, the cylinder was lubed and I've not had that rusty spring squeak sound since. Very Happy
Unfortunately the pedal squeak comes and goes. If I hit the spring with silicon spray, it goes away for several weeks.
In my case, the secondary squeak is due to the fact that I shift in a lazy manner - instead of having my foot square on the pedal, I tend to have it at an angle, and this put a bit of pressure (forcing it to the left) - hence the squeak.
Post #80749 18th Jul 2011 8:50am
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
I have the same - i have been told it's because of when the master brake cylinder leaked... www.ralton.co.za
Post #81133 20th Jul 2011 5:20am
Bomber82
In my case, no leackage anywhere.
I'll try silicon oil on the master cylinder Matteo
Post #81196 20th Jul 2011 3:46pm
