![]() | Home > Tdi > Under The Bonnet Upgrades? |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 640 ![]() ![]() ![]() |
If you can find any second hand, Twisted used to sell stainless steel intercooler pipework for the 300tdi to replace the restricted standard lower pipe and the over long rubber / silicon top pipe which is prone to swelling under boost.
I doubt they do any now as they’ve moved onto greater things. I’ve had a set on mine for the past 10 years or more. I fitted the Allisport intercooler at the same time, and a bit later the alloy cyclone breather (mainly to cure the annoying oil leak they always develop) and header tank. |
Ps fitting the aircon nose makes fitting the Allisport full width intercooler a lot easier, otherwise the standard grille surround is rammed right up against the cooler and still needs bits cut off it.
The aircon noses are pretty cheap now for pattern ones but that wasn’t the case ten years ago, I think mine cost almost as much as the intercooler. |
Fatbaron Member Since: 12 Mar 2016 Location: Devon Posts: 299 ![]() ![]() |
Cheers Oldowner, I'm pretty much replacing everything I can under the bonnet with the Alisport stuff, including the XL surround for rad/intercooler.
I've bought the full set of silicone hoses which I think includes the pipes you mentioned. ![]() |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3350 ![]() ![]() ![]() |
While you are at Allisport check out header tank, airbox, oil catch can and power steering reservoir.
With the other stuff you have mentioned your under bonnet bling will be pretty much sorted then. WARNING. This post may contain sarcasm. |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 ![]() ![]() ![]() |
I fitted the Alisport intercooler to my 110 300tdi and did not notice much improvement.
Then I took it to Gwyn Lewis for "Injection pump optimisation". I had a very wide grin after the test drive. My 110 commercial (relatively speaking) flew! ![]() |
I've been trying to give Alisport my business but can't get hold of them, 4 emails and phone calls this week and nothing back! Anyone else have trouble?
I'm sending the truck into Devon 4x4 cause I just don't have the time to do it myself so I'll get them to look at "injection pump optimisation ". ![]() |
