Home > Puma (Tdci) > Windscreen Wipers - very strange.....
Swim_Cap
United Kingdom 2009 Defender 90 Puma 2.4 HT Zermatt Silver
Good evening all!
So my windscreen wipers kick in when I turn the key 🤔 I’ve change the wiper arm switch, the relay and the wiper motor park switch; and it’s still happening! Can somebody point me in the right direction to resolve this issue please?
2009 2.4Tdci
Thank in advance 👍
Post #801093 6th Nov 2019 7:45pm
Park switch is the obvious culprit. Have you actually tested the operation of the switch rather than just assuming that the new one works?
Post #801100 6th Nov 2019 8:11pm
Swim_Cap
Hiya, no I didn’t I changed for a new item. How do you test it?
Post #801108 6th Nov 2019 8:26pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
If you remove the park switch but leave it connected you can operate it manually to test.
I had one where there was some play in the wiper gear shaft that meant the white plastic bit on the gear wasn't operating the switch properly. Had to fit another washer behind the spring clip to bring it nearer.
Post #801163 7th Nov 2019 8:54am
As Scotm says, if you unclip it from the motor you can operate it by pressing the operating pin.
With the wiper switch off and the ignition on, the wipers should run with the pin released (the motor thinks that the wipers are not parked) and should stop abruptly if the pin is pressed. If this happens, the switch is working, however it may still be the case that the cam on the motor gear wheel is not operating the switch properly. In this case, try Scotm's suggestion.
The park switch operates by (in the not parked mode) connecting the motor's low speed connector to an ignition-controlled live feed and earth connector to earth, and (in the parked mode) by disconnecting both and shorting them together so that the back-EMF of the motor acts as a brake.
Generally a park switch fault if the only thing that will cause a wiper motor to run when switched off (the motor thinks the wipers are not parked).
Post #801170 7th Nov 2019 9:04am
Swim_Cap
Scotm & Blackwolf - thank you so much for this information! I will strip it down at the weekend and test the switch, and the old switch that I took off, to establish where the fault is.
Thanks again - what a great Forum Thumbs Up
Post #801183 7th Nov 2019 11:20am
