Home > Puma (Tdci) > fob/ indicators |
skidrov Member Since: 06 Oct 2013 Location: Melbourne Posts: 55 |
Sounds like fob battery. Check the appropriate owner's manual section, it gives the symptoms and the change procedure.
6th Nov 2019 8:30pm |
dcpallets Member Since: 27 Dec 2018 Location: colchester Posts: 26 |
have two fobs one doesnt flash indicators on unlock, then used the other but used to flash indicators when you unlock , now that doesnt , ,
6th Nov 2019 8:34pm |
I would replace both batteries. Even if wrong, not much to loose, easiest fix. But, check/follow the owners manual process.
6th Nov 2019 8:37pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3674 |
Batteries
7th Nov 2019 6:01am |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1031 |
Is the lack of flashing by design to let you know the batteries are nearly dead? I recently had the problem of not being able to unlock one morning - turned out to be the battery in the fob. 2 weeks later I'd have been on holiday and have been in a real pickle.
7th Nov 2019 9:01am |
Yep, all in the manual. Guess how I know... 😋
7th Nov 2019 9:25am |
I take it you looked after the battery went flat?
7th Nov 2019 9:52am |
