![]() | Home > Puma (Tdci) > Trim Missing |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1852 ![]() ![]() ![]() |
Looks normal for a front door sill to me!
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4801 ![]() ![]() ![]() |
As above, normal. You can, however, get a stainless steel finishing trim to make it look more complete
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
AKL Member Since: 12 May 2017 Location: Nyumbani Posts: 18 ![]() ![]() ![]() |
Thank you both for the reply - just found it strange why the sponge would just suddenly tear and leave holes - guess a Defender so anything possible
mobilesawmiller Member Since: 03 Mar 2013 Location: Co,Tyrone Posts: 100 ![]() ![]() |
Something like this?
Have circled in White the bit where the sponge has come off in picture
Aaah the foam, it stops small bits of gravel getting stuck between the sill trim and inner sill bar
![]() I personally would remove it completely as its a bit of a moisture /dirt trap ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 602 ![]() ![]() ![]() |
Mmm, don't have that on mine!
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5868 ![]() ![]() |
I’ve fitted sliders, but then fill the gap with sealer. That foam is horrible stuff.
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1111 ![]() ![]() ![]() |
Thank you - task for the weekend
