![]() | Home > Puma (Tdci) > Random Starting Issue |
rotating switch on the back of the key lock. Changeable (the switch, not the whole key lock mechanism) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6652 ![]() ![]() ![]() |
Sounds similar to this: https://www.defender2.net/forum/topic69729.html?highlight=duff
That thread has gone quiet but might give you some pointers. Happy to help with more pointers if you try some things and they work/don't work ![]() ![]() ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20688 ![]() ![]() |
Be sure that your battery clamps and ground feeds are secure. It sounds simple but can be a cause of a lot of issues.
They can look it, feel it possible but they need to be tight and clean. Only takes a minute to check, and worth doing just in case before further investigation. TheThunderRolls🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
diduan Member Since: 13 Oct 2016 Location: Central Balkan Posts: 260 ![]() ![]() |
I had the same problem and it was the main relais having poor contact. Take it out, clean the pins and put it in again. Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt |
