![]() | Home > In Car Electronics > Electrical Novice - Wiring thickness for extending LED Bar |
DuncanS Member Since: 06 Dec 2013 Location: Cumbria Posts: 299 ![]() ![]() ![]() |
Hi Oliver.
Something doesn't add up there. it can't be 510W and draw 12A at 24v. That would only give you 288W based on 12A at 24v. Normally for a lightbar you will use between 3mm and 6mm CSA (cross sectional area) depending on your spec. We sell cable at K&S McKenzies but its readily available at most decent auto factors. 12 Volt Planet, Vehicle Wiring Products and PoleVolt are probably my three recommended go-tos for online purchases. cheers North Cumbria Search and Rescue - Team Leader |
othorton Member Since: 22 Jul 2019 Location: London Posts: 104 ![]() ![]() ![]() |
Thanks very much for getting back to me Duncans. I agree; doing the math, it looks like a 510W bar would be working around 22A rather than 12A. I'll get in touch with GRP 4x4 as perhaps they got their figures mixed up as it does seem there's some confusion here.
Out of interest - is there any issue with using thicker than 6mm gauge wire other than its higher cost? Thanks, Oliver |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
Nope, use the largest diameter cable you can (within reason) as it will also minimise the voltage drop.
Personally though, 6mm is too thick for your application. . You will find 6mm too big for most crimp terminals and hard to crimp without proper equipment. Steve 02' 110 TD5 Double Cab Rebuild Thread |
Thanks Steve. I'll stick with 4mm then. That's rated to 40A which should be more than enough.
Really appreciate the advice. Thanks, Oliver |
