Home > Maintenance & Modifications > Mud deep A pillar trims
Saw these on FB pop up: https://www.mudstuff.co.uk/mud-a-pillar-tr...HFh8ZpYbJ8
Has anyone tried these?
They say 20mm extra but real world views are much better.
I canโ€™t make my mind up if theyโ€™d benefit for cabling or not. No Guts, No Glory.
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #799201 23rd Oct 2019 5:43pm
donmacn
I have them, as I always struggled to get cabling into the standard ones.
As my car was a basic spec 1994 model, I've had to add lots of stuff myself, so the likes of a CB antenna, hands free phone mic; dashcam power; auxiliary rear light; speaker cabling etc etc.
I'm quite happy with them - once they're on, you really don't notice that they're not standard. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #799213 23rd Oct 2019 6:33pm
I'd not seen those, useful to know about them.
Post #799214 23rd Oct 2019 6:35pm
Thumbs Up
I'm very tempted to give them a go as I know the factory ones are tight behind there already and I need to add a bit more.
On a side note, is the MSS glove box Mud sells the best one? If so, I may as well go for that too. Whistle No Guts, No Glory.
Post #799236 23rd Oct 2019 8:51pm
boode
England 2003 Defender 90 Td5 HT Rutland Red
I have the Mud A pillar trims and they are excellent
I have a lot of extra wires for - rear speakers, microphone, positive feeds from the battery - probably about 8 to 10 extra each side
With the extra capacity of the Mud trims they fit easily - no more pinched wires for a flattened rear wash hose
They also look standard
I would highly recommend them Thumbs Up
Post #799241 23rd Oct 2019 9:05pm
Tegner
United Kingdom 2010 Defender 90 Puma 2.4 HT Zermatt Silver
Mud pillar trims
Definitely a good buy I have extra cables for GPS/phone and dash cam all contained with room to spare
Post #799287 24th Oct 2019 9:47am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
I wonder if the lower ends reach behind the dash as the original ones do?
Can you see the cables in these corners? I can't make it out in MUD's photos.
Post #799289 24th Oct 2019 9:54am
I bought them. Will see how it goes.
Perfect timing for me to spot these.
Going by the interest in these I imagine theyโ€™ve had a few orders from here alone. Laughing No Guts, No Glory.
Post #799290 24th Oct 2019 9:56am
Tegner
no cables visible on mine
Post #799314 24th Oct 2019 1:31pm
Fitted mine the other day, very pleased with them.
They took all the extra wiring fitted behind them which the factoryโ€™s ones would not have done any where near.
As has been mentioned, once on youโ€™d not notice the difference, exactly the point in them and hid all of my cables even a 6mm physical dia feed. Plus others as well. Keeps everything much neater and tidy.
Pics:
Hopefully maybe of interest to others so you can have a proper gander at them. Thumbs Up No Guts, No Glory.
Post #800145 31st Oct 2019 12:09am
L110CDL
Looking good there Steve Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #800242 31st Oct 2019 7:55pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I always find that the pinch point is the area around the screw fittings on the standard Land Rover one's. Do this replacements have the same problem? Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #800295 1st Nov 2019 9:00am
Zed
Seems a good solution. My wiring has decent space under the standard fitting. What extra stuff are you running through there? WARNING.
Post #800311 1st Nov 2019 11:14am
You have to be careful still you donโ€™t trap the wiring behind there.
But there is lots of wiring room down the side of the fixing which makes it much easier too put back safely and securely.
There definitely is about the room estimated that they quoted. Iโ€™ve got a 6mm video cable behind one and factory wiring plus multiple 1mm2 twin feeds too around 4mm x 2mm.
Drivers side is tightest due to factory wiring but they fitted everything I wanted.
So in essence as they say, if your new additional wiring is up to 20mm deep then it will be suitable.
Unfortunately I didnโ€™t get a photo of the rear but they are exactly the same as factory only deeper.
They are easier to re-install and keep the wiring or tubing away from the screw too. No Guts, No Glory.
Post #800316 1st Nov 2019 11:40am
