Home > Maintenance & Modifications > Oil Temp Sender Thread size? Puma |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
1/4"x18tpi NPTF 1988 90 Td5 NAS soft top
2015 D90 XS SW |
18th Oct 2019 11:59am |
Baytown Member Since: 30 Jan 2016 Location: Cairns Australia Posts: 83 |
Fantastic.
Thank you Martin. I just need a 1/4 to 1/8 reducer for the centre port in the adaptor then. Good on you.👍 |
19th Oct 2019 5:30am |
Don’t you need a 1/4 - 1/4 - 1/4 t piece fitting?
Nothing you are trying to fit is 1/8 1988 90 Td5 NAS soft top 2015 D90 XS SW |
19th Oct 2019 7:01am |
Hi mate.
No, as the threaded male end of the pictured fitting is 1/4 inch. It should fit the block. The other end has the Redarc 1/4 inch temp sender fitted. I need to fit a 1/4 inch to 1/8 reducer into the 1/8 centre port on the fitting so I can attach the factory 1/4 inch pressure sender. Simples😗 |
19th Oct 2019 7:24am |
You're quite right, I was thinking of it from the other end 1988 90 Td5 NAS soft top
2015 D90 XS SW |
21st Oct 2019 10:10am |
