![]() | Home > Puma (Tdci) > Questions prior to buying second-hand '08 110 XS |
Most of your questions have been answered on hear already,pm me the reg no., and I'll hpi it for you. 2.4 90 XS
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2467 ![]() ![]() ![]() |
Look at the bulletins Eduardo has posted. Also try to check the traction control unit as some vehicles, as far as I know, are a bit dodgy sometimes. Puma 110" SW
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 ![]() ![]() ![]() |
Thanks for the tips... I'll gladly be spending some more time here researching!
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
Are they? I'd not come across this one. In what way does it show up? Mine appears to be working fine but I'd like to know what to look out for. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
I believe read in this forum people complaining about it. I recall sometimes sensors get dirty or so. Puma 110" SW
Setok Member Since: 16 Jan 2009 Location: Helsinki Posts: 422 ![]() ![]() |
In collisions the Defender is apparently one of the safest cars out there. I can't remember where I read it, but based on UK statistics, the best car to be in in a collision is a Defender, with only 1% of all car-on-car collisions leading to fatal or serious injury. It was quite literally top of the league.
mse Member Since: 06 Apr 2008 Location: UK Posts: 5087 ![]() ![]() ![]() |
DfT Mike |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
Easy,, mine have been out 3/4 times now, simple bolt job, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Fontuin Member Since: 11 Sep 2008 Location: South Africa Posts: 29 ![]() ![]() |
Is it easy to remove that 'hump' in the middle of the floor that holds the seats in place too? |
[quote="Fontuin"][quote="TJ101"]
Yep,,8 screws holding the plastic trim, then 8 ?? bolts and out it comes California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
