Home > Maintenance & Modifications > Hole footwell!
dioliahary
Hole footwell!
Pulled my carpet up tonight and came across this. Argh rust on my truck. Struggling to make the set up out. Looks like it’s double skinned. Underneath and the inner side of the outer skin is surprisingly solid. However the inner is rusted through. I am not sure but the inner skin looks like.a repair has been made, but the repair has gone straight over the rotten inner floor. So I have options, one is to thoroughly clean, derust and protect then repair with a steel plate. Also anyone know what the screws are for . I Just cannot seem to understand the profile of the floor (double skin etc ).
 1990 200tdi conversion 90
Post #798353 15th Oct 2019 9:07pm
Hal
Might be useful understanding whats there
Hal
Post #798356 15th Oct 2019 9:25pm
donmacn
Slightly hard to tell from the photos, but aren't those screws where the bulkhead to chassis bracket is? Maybe machine screws were used to keep a low profile in the footwell?
Can't help on the double skinned thing. It does sound like a bodged repair though.
"Rust on my truck." I know just how you feel. It's why I replaced with a galvanised bulkhead eventually. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #798374 15th Oct 2019 11:33pm
dioliahary
Been searching all night and think it’s original metal. The second outer skin on the passenger footwell has rotted through. I plan to cut back to good metal, buy a footwell panel, have it reinforced then fit. Will clean the drivers side and protect as looks like surface rust only. 1990 200tdi conversion 90
Post #798375 15th Oct 2019 11:39pm
dioliahary
So floor plates out and quick clean, all doesn’t look too bad and happy that the chassis rails look good. I have ordered a galvanised repair kit and will fit with sealant (sikaflex) and rivet.
Going to clean, de rust, protect etc. 1990 200tdi conversion 90
Post #798440 16th Oct 2019 9:18pm
Oldowner
It’s an MOT fail if footwell is rivetted in - it must be welded in as per original.
Post #798441 16th Oct 2019 9:24pm
dioliahary
Not cutting out all the section just the bad stuff probably about inch. I have purchased a galvanised section which would need specialist welding. The section will give me back the rusted lip. 1990 200tdi conversion 90
Post #798443 16th Oct 2019 9:48pm
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
It Shouldn't be too tricky to weld. Best bet is to grind off the galvanised costing, weld in and then use a galavanised zink primer before painting.
Oh and you would need a respirator.
Post #798494 17th Oct 2019 11:47am
Retroanaconda
It needs to be properly repaired (welded) as it's within 30cm of two prescribed points, the body mount bracket and the pedal mounts.
Not that it's likely anyone would notice of course.
Post #798499 17th Oct 2019 12:39pm
dioliahary
It's getting welded, just waiting for the repair kit. 1990 200tdi conversion 90
Post #798956 21st Oct 2019 6:56pm
zippo87
Scotland 1996 Defender 110 300 Tdi CSW Epsom Green
You’ll have to excuse the vulgar language, but is this just the light - or is that a gaping hole in your bulkhead!? 😂
Post #798969 21st Oct 2019 9:05pm
dioliahary
Yes, the bottom corner has rotted, I intend to grind back to good metal and weld a replacement plate in there. 1990 200tdi conversion 90
Post #798970 21st Oct 2019 9:12pm
