Home > Puma (Tdci) > OMG MAF cleaned and WOW
Page 2 of 3 <123>
bear100
That is dirty! Minch you have started something here!! Lol can’t wait to do mine Very Happy 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #796383 2nd Oct 2019 6:50pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Never thought of it but took the maf out and cleaned it with contact spray. Didn't expect anything as I didn't even had an error code. Unexpected results. Happy man!
Post #797107 7th Oct 2019 1:44pm
ChrisCSL
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Thanks Minch and Everyone,
Did mine today, no problems (after I found the MAP sensor). No prior fault codes or really dirty sensors found as far as I could see. My MAP sensor looked a bit different from yours. The cone bit didn't have gaps in the side. Mines a late model 2.2. Anyway, truck started ok afterwards but not driven yet to see if I can notice any difference. I do think the tick over idle is slightly lower than before though which is a good sign.
I did notice my Urban (ITG) performance air filter looked a bit dirty with a very small bit of debris. I'll wash it, dry overnight and re-oil when I get a chance.
Love this forum. I've learnt so much in a short amount of time as a defender newbie. Thumbs Up
Chris
Post #797744 11th Oct 2019 5:11pm
I think the later sensor is better protected but oiled filters such as the IGT really are the enemy of these things. Better to stick with the standard paper element, which has been proved to be more efficient anyway. Darren
Post #797764 11th Oct 2019 7:41pm
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
TD5 2001
Forgive my ignorance but would any of this apply to my TD5? Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #797793 12th Oct 2019 1:20am
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
Quite right. Pete from BAS tested serveral 'performance' filters against the standard one some time back (sadly the post's not on here any longer) and the most power came from the standard one.
Post #797799 12th Oct 2019 6:23am
ChrisCSL
Thanks.
Understand the test that was done which I’m not disputing. Alive had better results on the dyno with ITG over paper with my remap, intercooler and exhaust set up.
Chris
Post #797800 12th Oct 2019 6:36am
Joe the Plumber
That's fair enough Chris, thank you. It just goes to show there's often no definitive answers when it comes to tuning.
Post #797807 12th Oct 2019 7:03am
ChrisCSL
It’s a dark art 😉
Post #797831 12th Oct 2019 10:08am
chrisc2306
Scotland 2011 Defender 90 Puma 2.4 CSW Zambezi Silver
Has anyone gone as far as removing the intake manifold and hoses etc to clean them out. I just find it amazing how much gunk collects on the MAP sensor that I'm considering giving the whole system a clean
Post #810255 14th Jan 2020 8:37pm
hank
I asked the same question in the last post of the below thread but got no response
https://www.defender2.net/forum/topic68596-45.html
I would also like to do this when time permits having seen seen some horror photos around the internet!
 > 110 XS Double Cab
Post #810289 15th Jan 2020 7:15am
hank
Back on topic, I cleaned my MAF over the Christmas period using Liqui Moly Air Flow Sensor Cleaner
Sensor was pretty dirty but in honesty I noticed no noticeable difference in performance
https://www.amazon.co.uk/gp/product/B00295EEBK > 110 XS Double Cab
Post #810290 15th Jan 2020 7:18am
Gloucesternige
United Kingdom 2011 Defender 90 Puma 2.4 HT Keswick Green
Yes, I have.. in fact I've stripped the whole bloody engine!!
The crap that was built up in mine was unbelievable, it must have been about 4mm thick all round the intake tube where the MAP goes and the plastic inlet manifold and inlet ports were nearly as bad. It's a combination of EGR crap, breather oil mist and oil from the Turbo. Oh yeah.. my 2011 had only covered 16000 miles, and a lot of that was long distance driving, so no pottering about with short journeys.
Here's my inlet valves.. &t=196s Nige
Check out my You Tube channel
https://www.youtube.com/c/Defender90KeswickNigelsLandRoverchannel
Post #810794 17th Jan 2020 10:28pm
X4SKP
I used the 10K Boost MAF Cleaner, prompted by seeing the P1103 Fault Code
The MAF Unit looked OK on inspection, but probably worth a regular clean at service time
or at what would appear to be a 10K recommended 'boost' interval.
I would only use a recommended cleaner on them as these units are expensive at around £140 + Vat
(£168.00 Inc) from Land Rover, there are factored claimed equivalents on the market at around £70.00 Inc
She ran well before and after cleaning the MAF, the Fault Code self clears after about 6 engine cycles, or via a
Scangauge request... I get the P1103 Code maybe once a year.
The 10K Boost was about £10 SKIP
Post #810865 18th Jan 2020 4:22pm
UtilityTruck
I cleaned my MAF and MAP sensors last night. Neither were particularly dirty, in fact the MAF looked like it’d just come out of a box from LandRover, and that’s after 70k Miles! The MAP had a little black gunk evident.
After a short drive no effects were noticed, but I’ve just done 25miles and I think there is a subtle yet noticeable improvement. Best way to explain it is the engines response to throttle seems a little more linear, less hesitation as you roll off and then on to the throttle, possibly just a little more free and happy to rev at the top end too.
As others have said, probably something to clean from time to time to keep the engine running well, but I won’t bother every service. 2014 Keswick Utility 2.2
Post #811581 23rd Jan 2020 8:12am
Page 2 of 3 <123>
