Home > Td5 > wipers |
Wiper spindles through the bulkhead probably seized. Pop the rubber cap of the outside and spray with copious amounts of wd40 while working the wipers. Ray
28th Sep 2019 6:03pm |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1761 |
Ooh hello stranger, not seen for ages then twice in one day
28th Sep 2019 6:31pm |
was that you on Leeds Road? I wasn’t sure because I didn’t have my glasses on Ray
3rd Oct 2019 5:52pm |
MJN110 Member Since: 18 May 2015 Location: North Yorkshire Posts: 380 |
This happened to me recently and I ended up having to replace the spindles and drive to them as i was unable to free them up with WD40.
To replace them is a lengthy job involving stripping out your dashboard so allow plenty of time to do it. If you do a search under wipers there is a lot of good advice on completing this job. I t is worth replacing the wiper park switch whilst in there as a precautionary measure whilst the dashboard is stripped down they are known to be a problem. 2016 Defender Landmark 90 2005 Defender CSW TD5 90XS |
4th Oct 2019 5:33am |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 932 |
Don’t use WD40 on your spindles unless it's their penetrating oil. Be sure to use a good penetrant, original WD 40 is useless as a penetrant. Good luck! 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
4th Oct 2019 2:16pm |
dave geldeard Member Since: 28 Sep 2019 Location: lancashire Posts: 2 |
Cheers for the replys dave.
4th Oct 2019 6:54pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2759 |
Had to replace both spindles on my 110 TD5.
Make sure you fit genuine LR parts. I found that the rubber sealing boots on aftermarket ones didn’t stop water ingress to the spindles. The job takes a while but it’s not difficult. |
4th Oct 2019 8:07pm |
When i replaced mine I packed the cap and external spindles with corrosion block water proof grease. 2016 Defender Landmark 90
5th Oct 2019 5:57pm |
