Home > Td5 > center console switches |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 490 |
I just finished retiring a friends 200tdi 90 with the TD5 dash and used these for switches and connectors.
Connectors https://www.ebay.co.uk/itm/5-way-connector...2749.l2649 Heated seat switches, on/off action, a lot of others are momentary. Will fit in upper row https://www.island-4x4.co.uk/switch-genuin...35393.html 2015 RRS Autobiography SDV6 1994 Def 90 300tdi |
2nd Oct 2019 6:00pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6611 |
Or connectors from this forum's site shop...
https://www.defender2.net/shop/5-way-defen...3-p71.html Disco2 switches do fit, they are exactly the same body. What you will find is that the switches are only meant to fit in one location, this can be solved by removing the "keyway" on the switch body when you come to fit. If you can source what you want from the Disco2 options then great, then order the remaining ones from the UK 1988 90 Td5 NAS soft top 2015 D90 XS SW |
2nd Oct 2019 6:14pm |
commoguy Member Since: 25 Apr 2018 Location: Southeast, PA Posts: 19 |
thanks gents. was not even aware of all what was on the shop here. ill have to check shipping to US. Ill explore the D2 situation nearby and will likely get the rest from your side of the world. It's where my TD5 stuff came from anyway. Appreciate the info. Would love if the Mud dash replaces and allows for carlings, but dont just want an overlay.
2nd Oct 2019 6:42pm |
I have a mud dash in a 300tdi, does look good but having just done the td5 dash, that looks good a# well. The one downside of the td5 dash is the proper switches aren’t necessarily on/off which I wanted for the one I did 2015 RRS Autobiography SDV6
2nd Oct 2019 6:53pm |
were they momentary instead? which switches didn't operate the way you wanted? |
2nd Oct 2019 7:16pm |
Rear fog, rear wiper, I forget which others. most seem to be momentary to another relay but I was already fighting with turbo diesel chassis loom, 200tdi engine, late 300tdi loom and td5 dash so wanted the easy option of on/off 2015 RRS Autobiography SDV6
2nd Oct 2019 7:32pm |
thanks, good info there. I'm in a similar situation. I have 91 D90 w/ 200tdi, so will be integrating that harness to the TD5 dash panel. I will have to find what switches can be adapted.
2nd Oct 2019 8:34pm |
Have a look here
https://www.landyzone.co.uk/land-rover/defender-switches.194709/ 2015 RRS Autobiography SDV6 1994 Def 90 300tdi |
2nd Oct 2019 8:41pm |
You can easily swap the caps between switch bodies, e.g. to make a latching fog light switch. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
2nd Oct 2019 8:49pm |
Im going to purchase a bunch of YUF500150LNF from the local dealer in the states. Only about $6 a piece. Will look for some caps to find different options.
Anyone have the PN for the correct fitting electric window switches? Is there a central door lock button? Bought some puma doors and they have central locking. |
4th Oct 2019 4:21pm |
