Home > My Defender > My 90 having a full rebuild
Page 15 of 16 <123 ... 141516>
MetalMatt
United Kingdom 1989 Defender 90 300 Tdi HT Baltic Blue
Quote:
Good that your still doing bits to the 90 Very Happy
Nice find with the water and just a few more holes to find for the rest of the water ingress Rolling Eyes
Yep bits still being done to the 90 but it has been slow over the last few months, but now getting married is all done, work can pick back up on finishing it off Thumbs Up
Yep it was a cold shock when the water that leaked in through the roof collected in the headlining and as i turned a corner it rained on my head Rolling with laughter
Think i am going to have to turn the hose pipe on and spray the car to find the rest of the leaking areas Exclamation 1995 Land Rover Discovery 300tdi - Sold
1989 Land Rover 90 - Rebuilding/built - its a project
2002 Land Rover Discovery TD5 - Sold
2017 Mini JCW F56 - Current Daily Driver
Post #777026 11th Jun 2019 9:44am
Fatbaron
Brilliant build thread mate, just read it from start to finish! Thumbs Up
Post #777036 11th Jun 2019 11:35am
L110CDL
Yes you certainly have a very cold shock when that happens all over you Shocked
You know that it wont leak the same when putting a hose over the 90 Laughing
Next time you go out in the 90, you should wear some waterproofs Wink 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #777257 12th Jun 2019 7:47pm
MetalMatt
Cheers Smile its still on going (they are never finished) but at least its now Tax, Tested and insured.
Just seen you have started rebuilding yours so looks like i am going to have to start reading your thread from the very beginning Thumbs Up Very Happy 1995 Land Rover Discovery 300tdi - Sold
Post #777315 13th Jun 2019 8:37am
MetalMatt
That is true i may not find the leaks but on the upside the other leaks that i need to trace all end up on the passenger side so SWMBO will be getting the cold shower instead Rolling with laughter
Next time might stick either a wetsuit or drysuit on when taking the 90 for a spin Thumbs Up Rolling with laughter 1995 Land Rover Discovery 300tdi - Sold
Post #777316 13th Jun 2019 8:40am
L110CDL
Sounds good that the other leaks are on the passenger side Thumbs Up
If you go in the 90 again, with a wet suit on, just put a surf board on top and no one would be the wiser Laughing 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #777534 14th Jun 2019 7:40pm
MetalMatt
Saturday the hottest day of the year so far and with a mate, i decide to pull the land rover dash apart to fix the broken windscreen spindle box thing (dont know the technical term), Then i also fitted a glovebox from raptor engineering
Out with the broken
in with the new
Then Glovebox went in
Post #779742 1st Jul 2019 10:03am
Procta
What is the glove box like? I ddi toy with the idea of getting one for the old defender. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #779755 1st Jul 2019 3:06pm
MetalMatt
Update,
Got the fuel gauge working and i am happy as it says there is half a tank of diesel in it so thats a bonus Thumbs Up Also got the second battery in and split charge system on and wired up the inverter Very Happy No photos of all this work as it was done when it was absolutely bouncing down and i was soaked and cold. Will eventually take some photos of the work done.
Getting back on with the water leaks, whilst the 90 was out in the torrential rain after i had completed the electrical work, i had chance to monitor where the water leaks are coming from as the drivers foot well filled that much up i could have had a gold fish swimming in it Laughing Cut a long story short it looks like the water is coming through the windscreen/bulkhead blocks and at the top of the A pillar, So looks like i am going to ditch the hinged window blocks and replacing them, and put new gaskets etc on to hopefully stop the water entering there and to re-seal at the top of the A pillar. Then will monitor for more leaks.
I know its a 30yr old landy and will leak in places but before the rebuild it never leaked in either of these places so i am determined to stop it.
Now its time to start saving for more of the fun Mods to get the old girl looking how i want it to look Thumbs Up Thumbs Up 1995 Land Rover Discovery 300tdi - Sold
Post #787593 19th Aug 2019 10:08am
MetalMatt
The glove box is a neat piece of kit, well made and looks good IMO, also good that it has vents at the top so still lets air flow through when the "Aircon Flaps" are open Rolling with laughter And is big enough to store a satnav and cables and a few other little bits in.
it wouldnt stop mr thief though as a well placed pry bar and it will probably rip out with enough force. But i aint gonna be try that lol 1995 Land Rover Discovery 300tdi - Sold
Post #787594 19th Aug 2019 10:12am
L110CDL
Productive up date there Matt, glad your getting to the bottom of the leaks, hopefully after the fixes your going to do, it will be all ok Wink 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #787754 19th Aug 2019 7:10pm
MetalMatt
Spent Saturday morning sealing up the roof with some black sika flex on the areas that were leaking so the only other job to do to hopefully stop the other area that is leaking is to buy some solid window blocks and get rid of the hinged ones. and then seal them up.
Then added the Raptor engineering switch pod and switches - not wired up yet but that will be in the next couple of months. So the interior is getting there also need to put the plastic cover back on around the steering column. Also need to relocate the inverter that i got
Post #788810 27th Aug 2019 9:29am
L110CDL
Nice progress with sorting out the leaking issue, hope the blocks fix is good as well Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #789227 28th Aug 2019 7:46pm
MetalMatt
New window blocks fitted, i have replaced the old hinged ones with the solid non hinged version. But by heck were they a Censored to remove, the two lower bolts came out with not much fuss the cross headed bolt through the windscreen frame though was a nightmare, after smacking it with the impact driver and nothing happening, i drilled it out and used a bolt extractor and after some brute force it eventually came out, its always the simple and easy looking jobs that seem to take up time.
Now to wait till i have some spare time to take it out in the rain Thumbs Up 1995 Land Rover Discovery 300tdi - Sold
Post #796325 2nd Oct 2019 11:59am
L110CDL
Good that you managed to get it done but as you said, it's always the simple jobs always take the longest time and they always do Rolling Eyes 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #796418 2nd Oct 2019 8:27pm
