Home > In Car Electronics > DRL wiring to ignition live
PCM
Probably a silly one, but it has me thinking. After a good search on the forum I'm still stumped.
I'm 100% buying a bumper with DRLs in the next few days (Just not sure which one yet)
I know you need to wire them up correctly so they dim with the side lights and go off with the mian beam. All ok.
First question is, where is the best place to actually take the power from for bumper mounted DRLs? Model Puma 2.2.
Do most controllers know the difference between alternator charging battery and static parked 12v battery. If so I assume i can run power directly from the battery box.
2) Is it therefore best to add another fuse/terminal box to the battery box? Any recommendations?
3) What's the best/neatest/most reliable route to take?
4) Or do i need to find an ignition live feed. In that case, where is the simplest / best option.
I'm assuming the DRLS will have an input for the side lights and main lights so wil just need to tap into these signals for them to do the legal thing.
I'm happy to wire the things up and am not totally inept. Smile just want to get my head around it in advance so I can get things prepared.
Cheers all
PCM
Post #796066 30th Sep 2019 7:05pm
mcma1
First thing I always do is order a blue sea A/B fuse box and ignition sense module from Tim at mobile centre. Just makes it dead simply to add things Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #796109 30th Sep 2019 8:27pm
mcma1
I am pretty sure the twisted DRLs come back on with full beam?? Andy
2014 Corris 110 SW
LS3 V8 build...
Post #796114 30th Sep 2019 8:42pm
PCM
So from battery I use one of the fuse boxes to basically make things tidy
Then use an ignition live module to turn thigns on with the alternator.
Will be adding heated seats in the back for the wee ones this winter, so need ot think ahead. (don't laugh, it's one up on the wifey with her rr sport as she can't put them in.)
Just to be idiot proof, do i need the below?
Post #796117 30th Sep 2019 8:50pm
mcma1
I use this one. Single ground, and then A for ignition and B for permanent.
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #796127 30th Sep 2019 9:38pm
PCM
Just bought a VSR sensing relay. HCC DUAL 'VOLTAGE SENSING' SPLIT CHARGE RELAY (VSR) 12v 140amp Pt.no.VSR12140HCC
Equivalent to DURITE 0-727-33
The ones from mobile centre were 100’s so took a chance with one from the bay.
However there is s warning about Smart alternators. Which I assume the Puma 2.2 is most certainly not.
IMPORTANT NOTE:-VSR relays are not suitable for vehicles with 'smart' or 'intelligent' alternators. Vehicles having engines complying with Euro5/6 or later emissions standards and/or incorporating regenerative braking will almost certainly be fitted with such alternators (check with your vehicle supplier). Such vehicles should use a 'battery-to-battery charger' device rather than a VSR (see the Sterling Power Products devices featured in our EBAY shop such as item no.182756980530 ).
Anyone had any issues fitting a VSR relay to a Puma?
Post #802441 16th Nov 2019 2:11pm
I've got one which is undoubtedly the same as that internally and it works absolutely fine. The alternator on a Puma is not in any way 'smart' in the way that description means.
 Darren
Post #802443 16th Nov 2019 2:16pm
PCM
Thank you. You're a star.
Thumbs Up
Post #802564 17th Nov 2019 12:56pm
spudfan
Ireland
I bought a bumper with Ring DRL'S. Two wires go to the battery terminals and the other to the live feed on the side light. The wires from the bumper DRL lights go to a control unit which I mounted to the inside of the panel on the intercooler side just behind the grill and from there to the battery. Have done two Puma's. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #807116 20th Dec 2019 11:08pm
