![]() | Home > Pictures & Video > Interesting video about catch-cans and EGR valves |
Wayne
In my (limited) opinion this isn't really related to the EGR function implicitly. The "catch can" just lessens the effect of the EGR in the gumming-up of your intake. It's almost parallel to the EGR. However the gunk caught in the catch can is prevented from being re-cycled into the inlet side of the engine, thus reducing dirty deposits. The EGR is related:
The catch can (I hope) is an easy fix to reduce SOME of the nasty stuff in the intake. It does not delete the EGR, it actually HELPS the EGR Altho my EGR is (sounds like) on the way out, I think I will be keeping the EGR, and when it fails I'll replace it (and probably try to fix my old EGR and keep it on the shelf as a spare). Cheers Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Also, FYI, My ProVent has been on for around 400 miles now. A few shorter journeys and yesterday a 300 mile drive from Silverdale to Aviemore, fairly well loaded inside, plus towing a small-ish trailer.
I sat between 55 and 65 mph, mostly on cruise. So far my catch can has not "caught" anything visible. A sign the motor is good I guess ![]() ![]() |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6324 ![]() ![]() ![]() |
hi Martin,
for starts if you like others are happy with the provent then that's only a good thing. I'm sure it can only be either nill benefit or a benefit and not detrimental to the engine so hopefully that's another good thing. I just realised isn't this thing catching the mist of the cylinder head? I need to have another look at the video. |
It is, Sir... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2318 ![]() ![]() ![]() |
I'm interested in this but have a few queries...
1. Has anybody removed the intake and cleaned out the crap? If so any notable improvement in engine performance? Everyone is interested in improving the restrictive intake system but this seems to have been overlooked. 2. Given the limited space, why is everybody using the provent 200? the 100 or 150 look fine from the specification? The 100 even has 19mm inlet & outlet and also the outlet can be rotated at 90degree intervals which may improve return plumbing to the airbox. https://oe-products.mann-hummel.com/filead...ion_EN.pdf > 110 XS Double Cab |
