Home > Technical > Heated screen wiring |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1782 |
I think mine is central power and two earths IIRC, earthed at the windscreen block bolts
Also because of the inherent design and heavily tinted rear windows with night time reflection I don't use the rear window much, don't have an interior mirror and use the rear camera if required, so I disconnected the feed to the heated rear window at the grey bulkhead multiplug and used the standard HRW circuit to power the windscreen - no timer but quick and easy and totally reversible. HTH Keith |
25th Sep 2019 2:12pm |
have look at the links below
https://forums.lr4x4.com/topic/4766-heated-front-screen/ https://forums.lr4x4.com/topic/8993-wiring...nt-screen/ |
25th Sep 2019 2:24pm |
Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 830 |
Thanks everyone, good reading. Soft top so no rear heated window 😂
25th Sep 2019 3:28pm |
MYSTERY Member Since: 14 Jun 2019 Location: Torquay Posts: 10 |
may be of use
Click image to enlarge |
12th Oct 2019 2:11pm |
