Home > For Sale & Wanted > [Wanted] Defender heated screen
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Defender heated screen wanted
ta
Post #789852 1st Sep 2019 9:46am
JR
Scotland 1984 Defender 90 200 Tdi SW Coniston Green
Some experience from my retro-fit heated screen into my 1984 90!
I did this around 10-12 years ago. I was offered 2 types of heated screen, a 2-wire and a 4-wire, and a clear or tinted version for both.
Being a bit naive with these electric things I chose the very slightly cheaper 2-wire as I reckoned it would be easier to install, I was WRONG!
Both screens have 2 zones for the heated sections, but the 2-wire connects them both together as a single circuit connection, whereas the 4-wire has 2 separate circuits, one zone per circuit. What I have found with my 2-wire setup is that the screen is pitifully slow to do its job!
My D2 has also been retro-fitted with a heated front screen, using the JLR standard loom that was pre-wired to accept an HFS, but the difference between the 2 is that the D2 one is dramatically quicker to do its job! It's quite obvious really, the 4-wire one has 2 circuits, one for each zone (left & right) whereas the Def one has a single circuit powering twice the area of the 4-wire! The screen on my 90 is now de-laminating badly at the bottom of the screen, resulting in large sections that no longer work. I intend to fit another bulkhead and will replace the screen with a 4-wire one fairly soon, re-wiring the circuitry to accommodate the extra circuit!
As I said above, the screen is de-laminating at the bottom, as shown in the bottom couple of inches going milky! I bought the screen through a plant glazing company, I intend to buy a better quality screen next time also, probably a Pilkington one as they are OEM!
Post #794483 22nd Sep 2019 12:44pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
Both mine have heated screens, one genuine, one snide. The snide screen distorts oncoming headlights which is quite distracting and annoying.I am tempted to swap for OEM
Post #794531 22nd Sep 2019 6:40pm
landy andy
Pilkington screen only would be my advise and was told the only screens commonly available are two wire ones, and this is what I’ve had on my last three Defenders.
Post #794539 22nd Sep 2019 7:00pm
