Home > Td5 > Identifying wires - Purple/Brown
steve_c3
United Kingdom 2002 Defender 110 Td5 SW Epsom Green
Can anyone help with identifying some wiring for me? I need to know what the purple and brown wires are that go into this plug behind the radio on my TD5?
Thanks in advance, Steve
 2002 Defender 110 CSW TD5
Post #793480 17th Sep 2019 7:09am
hank
Your vehicle is 2002 110 Td5 SW right?
Think it's the C0287 connector
https://www.lrworkshop.com/connectors/defender-2002my/C0287
Better ID's here https://www.lrworkshop.com/connectors/defender-1999/C0287 > 110 XS Double Cab
Post #793496 17th Sep 2019 7:57am
Martin
Site Admin
They are a permanent feed to:
Radio
Speedo (2 feeds)
Diagnostic socket
Interior lamp
From fuse 30 [5A] in the satellite (seat box) fuse box
The blue header splits a single incoming feed multiple ways.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #793514 17th Sep 2019 8:38am
steve_c3
Thanks Martin and Hank, much appreciated. I needed to know as after 2mins driving this morning, I had smoke coming from behind the radio and also from hole at the bottom of the OS B pillar and from the roof lining at the driver door (although this last one may have traveled up the pillar so originated from lower down).
Fortunately I stopped in time and disconnected the battery and the smoke stopped. Now I just need to trace the cause. Two of the purple and brown wires to/from the blue block have melted. The internal lights did stop working which ties up with Martins messsage. Looking in the satellite fuse box there is also a melted 15A fuse. Shocked 2002 Defender 110 CSW TD5
Post #793600 17th Sep 2019 1:20pm
NickMc
Check for rub through on the interior light wiring up the screen pillar and to the roof. You have a short somewhere.
Post #793721 17th Sep 2019 11:30pm
