Home > Puma (Tdci) > 2" OME Lift
Japseroony
England 2016 Defender 110 Puma 2.2 XS CSW Montalcino Red
2" OME Lift
Hi All,
I have just had a 2" OME lift kit fitted to my TDCi and when driving had an almighty "bearing going noise" so as a result have had to have a Double Cardon Joint Propshaft fitted to the front.
As well at that I now have a vibration at the back so think I need a wide angle prop on the back Exclamation Exclamation
Anyone any experience of this Question
Post #2368 11th Jun 2008 12:35pm
JSG
Not personally but it's quite common. Any lift will change the angle the UJ has to work at, castor corrected radius arms can help re-align things but double cardons are often needed.
Have you fitted castor corrected arms as part of the lift?
Post #2371 11th Jun 2008 1:38pm
AndrewS
Shocked No
Post #2372 11th Jun 2008 5:07pm
Bogblaster
United Kingdom 2016 Defender 90 Puma 2.2 Adventure Corris Grey
Nor have I Shocked I fitted OME Shocks and Springs a month ago and not a problem. 2019 MY Disco 5 HSE Lux
Audi A4 Avant 3.0L TDI Quattro - WOW
2016 90 Adventure
Post #2382 11th Jun 2008 10:08pm
Japseroony
They were fitted at the same time as the 2" lift - QT's with a 3 degree correction, which from what I gather makes matters worse on the front which is why I have had to go for the double cardon front prop Rolling Eyes
I think a wide angle rear should sort out the vibration from the rear and this has been mentioned by Cheviot 4x4 as well as Devon 4x4 - so more spare parts on the garage floor Rolling Eyes
Post #2388 12th Jun 2008 8:47am
AndrewS
AndrewS wrote:
Shocked No
Embarassed Spoke too soon the rear UJ of the front prop has gone. Replaced with a wide angel prop from Devon 4x4 about �130.
Post #2635 6th Jul 2008 2:29pm
Japseroony
AndrewS wrote:
AndrewS wrote:
Shocked No
Hi Andrew,
When I took the front prop off you could see that the joints were rubbing so whilst I think the wide angle will help you may still need a double cardon prop.
Hows the Bell remap doing? He did mine about a week ago and mentioned it was the same as yours - much more torque but somewhat more thirsty now Very Happy
Post #2642 7th Jul 2008 9:42am
AndrewS
My MPG has increased from 16 - 18 to 24 -26 Thumbs Up
Post #2644 7th Jul 2008 10:49am
jst
if you have castor corrected arms you will need the DC front prop as the diff is corrected ie closer to horizontal so the prop has a greater angle to work through when compared to running with std arms and NO caster correction where the diff will be nose up and hence a smaller angle for the prop to work through.
Plus 2" on the rear i would have thought would be OK with prop IF the shocks are with std mounting points and only +2". Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #3013 2nd Aug 2008 12:14pm
MK
Re: 2" OME Lift
Japseroony wrote:
Hi All,
Hi;
I`m new here. I was on the move to do the 2" lift considering already the change of the front prop. But, I`m surprised to know that also the rear prop has to be changed as well!
cheers
MK
Post #3370 28th Aug 2008 1:35pm
Japseroony
Re: 2" OME Lift
MK wrote:
Japseroony wrote:
Hi All,
Hi;
cheers
MK
Its something to do with the fact that the TDCi engine and gearbox are mounted further back which means the rear prop is shorter thereby making the angles more acute Exclamation Exclamation
Wish I had stayed with the standard suspension now Big Cry
Post #3373 28th Aug 2008 2:04pm
mse
I lifted the suspension once and i vowed then NEVER again - i couldnt see the point and the additional grief
So my suspension upgrades are only ever HD suspension and gas dampers. I also learnt the hardway with buying aftermarket HD rear disco springs - never again, genuine HD springs for me - the HD's lasted HD like for about a year before becoming Stds Big Cry Mike
Post #3375 28th Aug 2008 2:11pm
MK
Re: 2" OME Lift
Japseroony wrote:
Hi All,
Hi there:
what setup did you use for front and back?
thanks
M Puma 110" SW
Post #7914 3rd Mar 2009 1:56am
simonpuma90
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
I have a 2 " OME kit and had the same bearing noise so devon supplyed a DC prop and curred the problem but my steering has gone a little sensative cant say what exactly but im going to try the castor correction to see if it sorts that .
I still have the same vibration noise coming from the rear maybe I need a rear prop now do I Question Question
Post #7929 3rd Mar 2009 1:47pm
Glynparry25
It is that- have you tried having it aligned since the lift? If not, it is a good idea to do this- won't take it away completely but makes it bareable.
Glyn
Post #7932 3rd Mar 2009 2:25pm
