Home > Maintenance & Modifications > Cubby Box Fittings.
Anyideas
Cubby Box Fittings.
I removed the central cubby box from the 90 at the start of the build and now it appears I’ve mislaid them as I can’t find them. Sad does anyone know what I need? Also if anyone can help with the fittings needed for the rear bench seats too as I think They must have been with the fittings too.
Thanks in advance
Post #793169 15th Sep 2019 5:34pm
donmacn
best/easiest option will be to check out an online parts guide. If you google 'new LR cat' you'll find one I use regularly - I think I was pointed there by someone else on here.
This will give you some diagrams and part nos. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #793174 15th Sep 2019 5:47pm
sollner11
Germany 2016 Defender 110 Puma 2.2 SW Keswick Green
Post #793183 15th Sep 2019 6:32pm
Anyideas
Thank you both.
Post #793192 15th Sep 2019 7:10pm
