Home > Td5 > Another Td5 with belt chirp ! |
Alextd5 Member Since: 11 Feb 2017 Location: Gloucestershire Posts: 322 |
What do you guys think, I’m not convinced it’s the damper? Noisy injector? If I’m honest it’s always had a noise, but it’s become extremely noticeable in the last few days. Cheers Alex |
24th Jul 2019 8:44pm |
Any ideas on the knocking noise, mainly when hot?
I have replaced the crankshaft pulley.. I will wait a while before confirming the squeak has been cured! |
3rd Aug 2019 2:03pm |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 |
Dampners for the Td5 are available at Turner Engineering for £145.50
Mine has been squealing on shut-down for years. Replaced belts, tensioners still no luck. This is going to be my next step. https://www.turnerengineering.co.uk/lhg100...2x20634759 it's a Landrover thing... my renovation thread: http://www.defender2.net/forum/topic40792.html |
21st Aug 2019 4:31pm |
Paul V. Member Since: 01 Mar 2015 Location: Netherlands Posts: 18 |
Hi, what was the solution of your knocking noise ? Our Td5 has the same noise... Thanks, Paul |
7th Sep 2019 7:28pm |
Sorry Alex, i have a video but i have to find out how to upload 😳
Photo’s no problem. It all start with a dead injector. Bought a refurbished one at Craddock After the assembly and correct adjustment of the injectors and replacing the seals of the other injectors the engine was running very smooth. But with coolant temperature at 75 degrees during a testdrive i heard a ticking noise at idle. So i have the ticking/ratle only even the engine is warm. Pulleys, crankshaft camper are new. This morning a dieselspecialist had tested the craddock injector. The injector is performing well. -Engine does not smoke -Cilinder roughnes on my Hawkeye is good. ( between -1 and + 2) -No problem to start the car -No diesel in oil Does my problem sound like yours ? Did you solve your problem ? |
12th Sep 2019 10:14pm |
Photo’s no problem. It all start with a dead injector. Bought a refurbished one at Craddock After the assembly and correct adjustment of the injectors and replacing the seals of the other injectors the engine was running very smooth. But with coolant temperature at 75 degrees during a testdrive i heard a ticking noise at idle. So i have the ticking/ratle only even the engine is warm. Pulleys, crankshaft camper are new. This morning a dieselspecialist had tested the craddock injector. The injector is performing well. -Engine does not smoke -Cilinder roughnes on my Hawkeye is good. ( between -1 and + 2) -No problem to start the car -No diesel in Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge oil Does my problem sound like yours ? Did you solve your problem ? |
12th Sep 2019 10:15pm |
12th Sep 2019 10:20pm |
Yes. Sounds very much the same. I replaced all 5 injectors but it’s still doing it.
13th Sep 2019 8:27am |
Actually is it the same as yours ?? Difficult to tell
13th Sep 2019 8:30am |
I will add that not all diesel specialists can test Td5 injectors, having said that a bench test doesn’t always confirm a faulty
Or noisy injector. I was told this recently by a well established diesel specialist. |
14th Sep 2019 10:52am |
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge My dieselspecialist told me I had to wish that the other 4 injectors should be so good as the refurbished injector wich i bought from Craddock ! I let them test the new injector because of the engine noise and I was afraid that the needle in it was not closing correctly wich can destroy the piston. Last edited by Paul V. on 14th Sep 2019 2:30pm. Edited 1 time in total |
14th Sep 2019 2:09pm |
Click image to enlarge Yesterday I changed the engine oil from 5W40 to 10W40. Both full syntetic offcourse. I’ve also checked the famous oilpump bolt. The old bolt was correct tightened, and I saw a small sign of threadlock on it (Our Def is a 2004 car) With the new oil there was no difference cold and warm in engine noise. But I noticed something else ! With the car parked and engine running idle I heard the noise. Engine coolant was 91 degrees C. Then I slowly turned the steeringwheel....noise was almost complete gone ! After that I switched on the aircopump, noise completely gone ! Conclusion: when I asked for a bit of power to the engine the noise is gone. Bearings of the aircopump seems oké. With the belt of I noticed some freeplay on the steeringpump pulley. My waterpump is new. The pulley is correct mounted on the steeringpump axle. So what to do next.... Alex, would you check this also ? - to be continued - |
14th Sep 2019 2:29pm |
I eliminated the pulleys by running without the belt on when hot.. for a brief minute. The noise mine produces didn’t change.
I have checked and tested nearly everything I can, without stripping the engine of course. Since I noticed the noise I haven’t used it. I only know of three including yours which makes this noise! I think the next step will be finding someone who uses a picoscope.. whether this will flap up anything? |
14th Sep 2019 2:58pm |
I will try another ECU, although I’m 99% sure it’s not going to solve the problem, it keeps niggling me.
How many miles/km’s has yours done ? Mines done 83,000 although irrelevant, the other Td5 I know which makes a similar noise has done 110,000. Remapped, any modifications ? Engine work carried out recently ? (Apart from injector) |
14th Sep 2019 3:20pm |
