![]() | Home > Maintenance & Modifications > Front discs vented vs non vented |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
The only difference is fade resistance. They keep cooler for longer under sustained or repeated heavy breaking. Especially effective if towing or loaded
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6133 ![]() ![]() ![]() |
The vented also help if you run bigger tyres (like 255/85) as the extra diameter really makes a difference.... when I swapped an old 90 over to vented and was up laning in Wales, giving it "the beans" when out on the road bits, it really helped stop brake fade.
Worth the little extra cost
