Home > Maintenance & Modifications > Hex head drive flange bolts |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17441 |
Use hex socket head capscrews (what people incorrectly and annoyingly call "Allen bolts"), which are the right grade by default and widely available.
11th Sep 2019 4:52pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20440 |
I used as Blackwolf recommended, they did the job perfectly.
IIRC 10.9 or 12.9 are sufficient tensile strength but no lower. I have just checked the sizes you quoted against my old ones I took out I had them to hand luckily enough. The sizes you mentioned are indeed correct. M10 x 45mm Long. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
11th Sep 2019 5:12pm |
Oh and donโt use SS bolts. But in my case I did not use Loctite at all on the threads and instead used stainless spring washers.
Then torque to correct torque. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
11th Sep 2019 5:14pm |
v8steve Member Since: 18 Apr 2011 Location: dumfries scotland Posts: 195 |
just for the record.
10.9 grade standard . its bolts you want not setscrews (fully threaded) socket cap screws (allan bolts) are 12.9 grade as standard hope this helps 110 xs s/wagon s3 swb soft top |
11th Sep 2019 5:16pm |
As a matter of passing engineering interest, this is the difference between a bolt and a setscrew - a bolt has a blind (unthreaded) portion, a setscrew is threaded thoughout its whole length. Just thought you'd like to know. |
11th Sep 2019 5:17pm |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1862 |
Thanks very much guys, fascinating - but is there any chance of a link because I still can't find
If not, then no worries I'll make a trip to my local stockist called, believe it or not, Balls Grinding |
11th Sep 2019 5:28pm |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 917 |
https://www.ebay.co.uk/itm/M10-10mm-HIGH-T...vmQbn7SsLQ
Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
11th Sep 2019 5:30pm |
why couldn't I do that
Thanks so much , now I will have a good evening Rob 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
11th Sep 2019 5:33pm |
Thatโs the same supplier I used. $W33T $0U7H3RN $UG4R
11th Sep 2019 5:36pm |
When I did mine, I used galvanised socket head capscrews and matching spring washers, torqued to 65Nm:
Click image to enlarge I have the fronts to do shortly, when I've finished painting a set of HD drive flanges and my new wheels and tyres are ready: Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
11th Sep 2019 8:22pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
^^ ooh what a lovely half shaft you've got there
12th Sep 2019 5:36am |
Didn't think about washers
12th Sep 2019 5:39am |
Mine have gone rusty (of course) even though painted so any chance of a link to the galvanised version please Rob 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
6th Feb 2020 5:09pm |
Used them myself, but can't remember what for ~ not a name you can easily forget. |
6th Feb 2020 5:52pm |
