Home > Wheels & Tyres > Spacers yes or no?
LR110 BG
England 2009 Defender 110 Puma 2.4 SW Santorini Black
Spacers yes or no?
Guys,
I brought my dream (after 25 years) and it came with spacers on the wheels (I think 30mm). It makes it look more chunky which I like but a mate said that I should remove them as it can damage the wheel hubs! Is this true? This is my main everyday car so doing a fair amount of miles and will also be doing some green laning. I would welcome your thoughts. Photo below to show current look
Post #791275 8th Sep 2019 7:47pm
Sulisuli
It’s a real fan of worms, only my previous defender I had spacers on and did 100k miles without problems, but I’m sure others will have a different view on it Thumbs Up
‘Welcome to the forum and enjoy your defender 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #791278 8th Sep 2019 7:51pm
90 Dreamer
If they are a high quality 'hubcentric' type spacer then in general you should be OK.......
Post #791285 8th Sep 2019 8:07pm
JOW240725
I ran spacers for 2 years no issues. Vastly improved turning circle.
Welcome to D2N Thumbs Up James
Instagram @suffolk_rovers
Post #791287 8th Sep 2019 8:09pm
PCM
If you're worried about them loosening, just check them every 6 months and build up a history. I'd only be happy with spacers if I torqued the bolts up myself. And not a garage and a windy gun.
Should be fine. If i can't find the wheels I want soon I'll be buying a set myself.
Post #791293 8th Sep 2019 8:30pm
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
I run spacers and have never had an issue. The extra three inches is not going to create significantly higher forces on the bearings when you think what abuse they are designed to go through. Also a set of new bearings are pretty cheap.
Post #791304 8th Sep 2019 9:23pm
bear100
Had them on every defender without any issues what so ever, just buy quality items and use thread lock 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #791306 8th Sep 2019 9:35pm
bankz5152
As long as there are hubcentric you wont have an issue. I drive my daily on and off road. 35k later not an issue. Instagram @defender_ventures
Empire Tuning - Agent
Post #791323 9th Sep 2019 4:10am
hank
The laws of physics say yes they will cause more moment about the hub/bearing
Moment = force x distance
As you are increasing the lever arm (distance) by 30mm then the product of moment is greater.
However the hub and bearings are designed with a factor of safety to cope with such loads and it's really not a problem. Leave them on Thumbs Up You're mate is a negative nancy > 110 XS Double Cab
Post #791328 9th Sep 2019 5:14am
diduan
Bulgaria
Mine is on 33s and the turning circle without spacers is miserable. Never had problems but if it could be done without, I wouldn't put any. Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt
Post #791330 9th Sep 2019 5:51am
Re: Spacers yes or no?
The only issues you may have from quality 30mm spacers are (a) from half-witted insurance companies who for no particular reason think that they will massively increase the insured risk, and (b) from the fun police who know someone whose wife's brother-in-law was once told by a stranger that they can knacker wheel bearings (which they can't) or they'll just fall off one day (which is highly unlikely if you tighten the nuts to the correct torque).
I suspect that (a) originates from computer-generated statistics based on boy racers with slammed and rimmed hatchbacks, in which demographic it probably does indicate an increase in insured risk.
Post #791349 9th Sep 2019 7:25am
Fat Cog
Although looking at the pictures they make you LR illegal under Construction & Use Regs, tyres must not protrude the body line or wheel arches, some insurance companies would use this as a get out & I believe most people are getting away with it due to Police cuts and the demise of roads policing.
Other than that on a personal level I think spacers are a waste of time...I do a lot of greenlaning and despite previous comments, I've seen quite a few wheel issues, including them coming loose with extended off road use, and without exception its when spacers have been fitted.
Your choice though... Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
Post #791360 9th Sep 2019 8:08am
From the pictures I think that the OP is - just - legal, since the requirement is that the tread is within the arch viewed vertically from above. It is right on the borderline though.
Once upon a time I had 285 BFG KM2s on Boosts with 30mm spacers and they were similarly just legal but borderline.
Post #791374 9th Sep 2019 9:04am
Sulisuli
can of worms now opening Rolling with laughter 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #791387 9th Sep 2019 9:58am
AndrewS
Ive used Hubcentric spacers on loads of Defenders and proper off roaded them, I've never ever ever had a hub related issue, had lots of other problems with gearbox output shafts, clutches, rear drive shafts diffs etc etc.
In other words your truck is likely to develop drivetrain issues anyway. 130's have feeling's as well you know Smile
Post #791399 9th Sep 2019 10:27am
