Home > Maintenance & Modifications > What do you expect from “OEM” parts? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20111 |
OEM means aftermarket to me, can be anything only the brand reputation can you go by.
There are only a few parts that I actually know are guaranteed OEM that I will use. Air filters for example I won't trust unless Genuine. I am however happy with Ford Genuine parts, Bosch, Borg & Beck and Lucas. But only on certain parts. Genuine parts are not always great either, but most the time they are OK. NEVER SURRENDER! ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
7th Sep 2019 9:21pm |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 728 |
I think we all hope that OEM means that the item is nearly identical to the LR branded item, except for price. We mislead ourselves as you have demonstrated. All OEM means in reality is that the manufacturer produces parts for LR. It does not guarantee that the part is the same as that produced for LR.
However, if a part is supplied as suitable for our vehicle it should perform the same function as the original part. Clearly a part that doesn’t fit or do the job is sub standard and can be rejected. As we cannot see the technical differences before we purchase, then we are at a serious disadvantage, and suppliers too cannot warrant that a part is the same as that supplied to LR without expensive testing. Sorry to be so negative, but there are some suppliers who know that they are supplying poor quality parts. This is why this forum is so useful - we collectively supply quality control information to the members. |
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 158 |
"OEM" exists as it's the perfect storm of ambiguity that allows retailers/wholesalers to provide a different price point and navigate the murky waters between reality and a customer's interpretation.
Basically it could be: - a part that fits from an "OEM" for any vehicle? - an "OEM" part for Land Rover? - an "OEM" part for a Land Rover Defender of the model year yours is? - does "OEM" mean "Original Equipment Manufacturer" or does the retailer in their T&Cs say it means "Origin Ecuador Mainland"? - or anything else they can justify to be "OEM". You still have to do your research and you might get a quality part OR you pay genuine OR you pay for replacement/aftermarket that is probably crap. If you're lucky, the OEM part will be a genuine part at a non-genuine price. A reputable brand for wear/service parts is normally all that's required (Mahle/Mintex/GKN/etc.). A retailer selling an "OEM" part should list the brand of the part you're going to receive. LR Workshop Find a Defender's history and spec: https://defender.lrworkshop.com |
7th Sep 2019 11:25pm |
sollner11 Member Since: 31 Aug 2019 Location: Bavaria Posts: 7 |
here in long (best Site ever)
https://www.lrworkshop.com/guides/buying-new-land-rover-parts |
8th Sep 2019 9:03am |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 919 |
Always a dilemma at service time! Genuine LR filter kits are pricey (TD5 here) however I think it's better to spend the money on high quality oils and go for the medium priced filters, just my opinion
Sorry if that wasn't the purpose of the post! Mike |
8th Sep 2019 2:39pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3159 |
Summed up perfectly. |
8th Sep 2019 2:53pm |
Slideywindows Member Since: 09 Sep 2016 Location: North Essex Posts: 1283 |
It's the Original Equipment Manufacturer.
It doesn't guarantee that it is identical to the actual original equipment, or uses the same quality materials When buying parts for earlier vehicles OEM means even less, as the original manufacturer has probably been bought out for their name, and manufacture moved overseas for cheapness. What do I expect from OEM? Nothing. Britpart will probably use the same manufacturer...... |
8th Sep 2019 9:51pm |
