Home > Puma (Tdci) > Supplier Far Corners: any recent contact?
skidrov
Australia 2010 Defender 110 Puma 2.4 SW Fuji White
I'm wondering if anyone has successfully made contact with Far Corners, a UK-based supplier of various LR aftermarket add-ons: https://farcorners.co.uk/ They have a couple of nice Puma bits I'd like to pick up, but I've not been able to get an email reply, either via their contact form or direct email. I'm Australia-based, so need to "talk" to them to get a shipping quote before ordering.
Any recent experience in contacting them amongst the forum community? Are they still trading?
Thanks in advance!
Post #790631 5th Sep 2019 8:11am
Stacey007
Hello
I contacted them via the facebook page 'Far Corners'
I was after the rear seat extenders, then started e-mailing.
Sam Sorted my order very quickly and was delivered super quick.
Here is the e-mail contact I had called Sam
sam@farcorners.co.uk
Good luck
Post #790647 5th Sep 2019 9:55am
Sulisuli
Roy5695 has used them and they have been good to deal with Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #790661 5th Sep 2019 11:13am
skidrov
Thanks for the replies, folks.
Stacey007, yes, it's the rear seat extenders I'm after too - how do you find them? (And, that's the email address I tried...)
OK, will try them again - hopefully better luck this time.
Post #790813 6th Sep 2019 12:16am
jst
Several posts on here about them.
Product is good, if not initially fully tested, I think they work on principle of first customers pointing out any issues, same as lr. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #790834 6th Sep 2019 7:09am
Stacey007
Hello
The kids have a bit more room as it moves the angle of the back part of the seat so they are happy. They do not sit as upright.
I didn't fit them mind so not sure on the job, the garage did it for me when my car was in for a service and some other bits Smile
Post #790849 6th Sep 2019 8:34am
JOW240725
Kris at Far Corners is a lovely guy and very enthusiastic about what he does, but communication can be terrible. Keep trying they do some great products. James
Instagram @suffolk_rovers
Post #790874 6th Sep 2019 11:13am
skidrov
Ok: contact made, parts ordered! Will update with my thoughts once fitted. Thanks again for all the replies.
Post #790997 7th Sep 2019 12:29am
skidrov
...And now, seat risers received and installed. The ordering and shipping process was reasonably OK once contact was established.
The fitting process is fairly straight-forward. Instructions are rudimentary, but once you have the parts & car in front of you, it's pretty self-explanatory. One thing that I think the instructions did leave out is that you need to remove a threaded stud from the "old" assembly, to be replaced with a bolt from the kit. Again, once you're into the task, it's obvious and not hard to do. And, it looks like the kit used to include self-adhesive rubber pads to pad out the rubber stops, but now includes rubber rings that pack under the rubber stops to achieve the same end. Not whingeing, just trying to leave some hints for anyone who goes the same route. And, to be clear, the kit was entirely complete & self-contained.
Note that while I was able to do the "single" seat on my own, the weight and bulk of the "double" seat had me getting assistance when manoeuvring it around - the instructions quite correctly recommend this. Total time fitting a bit under 2 hours, tops, at a leisurely pace.
So, they're in, and the slightly more reclined seating position feels good. It does put occupants closer to the C-pillar as a trade-off; will have to load the car up with bodies and see how they find it. Note that this proximity to the pillar would probably not be noticed by younger/smaller passengers.
Also, the edge of the seats now brush against various trim fittings when folding & unfolding - not a biggie, you just go slow & careful when doing so. Never a bad idea anyhow.
Bottom line so far, does what it says on the pack, recommended.
Post #795548 28th Sep 2019 5:16am
90 Dreamer
any pix of the install??
Post #795562 28th Sep 2019 7:42am
skidrov
Sorry, no, but what you end up with is pretty much what you see on the Far Corners web site.
I'll take some of the areas I spoke about in particular over the next few days, ie trim rubbing & the rubber spacers.
Post #795566 28th Sep 2019 8:17am
