Home > Maintenance & Modifications > Heater fan control lever assembly |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 |
The heater control lever assembly in my second Wolf is all a bit broken. It seems there is a plastic trim panel to the outer side (facing into the car - passenger) and the whole thing is attached with screws into the dash assembly.
Mine is all wobbly as it has numerous cracks, so there is nothing anchoring the slider control, making it impossible to switch the fans on. My question is - is the plastic panel replaceable or do I need to replace the entire part (STC4848)? https://rimmerbros.com/ItemImages/Large/364943-Large.jpg 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
28th Aug 2019 3:02pm |
That is the metal dash assembly for the entire dash isn't it? 2016 D4 HSE
28th Aug 2019 3:50pm |
Click image to enlarge do you mean this |
28th Aug 2019 4:03pm |
Yep, part no is STC4848, looks like an entire replacement part is required 2016 D4 HSE
28th Aug 2019 4:28pm |
you can take it a part but if plastic part broken hole thing has to be replaced
28th Aug 2019 4:49pm |
So i ordered the new part and it arrived today, yet it doesn't come with the plastic trim side panel after all that. Brilliant!
I can't find a separate part number for it. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
2nd Sep 2019 11:50am |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 |
Do you mean the trim cover for the temperature blend lever (which is also the end of the dash)? Possibly one of these?
MWC9338PMA MWC9339PMA Isn't the fan speed lever cover part of the instrument binnacle and surround? (At work, so haven't got my vehicle to check against!) 2005 Td5 | 90 Station Wagon | Tonga Green |
2nd Sep 2019 12:22pm |
Doesn't the fan lever just stick out of a slot / gap between 1 and 10 below?
Click image to enlarge As this (stolen from African Uhambo here: https://africanuhambo.co.uk/2012/05/30/ins...ineering/) 2005 Td5 | 90 Station Wagon | Tonga Green Last edited by Green Machine on 2nd Sep 2019 12:30pm. Edited 1 time in total |
2nd Sep 2019 12:26pm |
I'll take a photo of it, it may help. I believe the fan control screws onto the side of part No 1 above, and has a plastic trim over it to make it look pretty, much like on the temp blend lever side. 2016 D4 HSE
2nd Sep 2019 12:28pm |
I think the fan speed lever assembly is screwed into the inside of Part no. 1. So the outside face that you're looking at is actually part of the instrument binnacle surround. Could be wrong.
Also you might as well consider replacing it with the steel version from Raptor (as in blog link above). Saves it breaking up again. 2005 Td5 | 90 Station Wagon | Tonga Green |
2nd Sep 2019 12:31pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2260 |
There is no plastic cover on that side. What you are seeing is the part that Dorsetsmith has linked to in his first post.
This part commonly breaks up and a plastic replacement will fare no better in time. Raptor do a metal replacement which is much better. Easy enough to replace just takes a bit of time to dismantle and reassemble. HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
2nd Sep 2019 1:41pm |
After much scratching of head and looking online, it seems I need the large part 1 on the diagram, it has all the supports. Mine being ex MOD looks like half of it is missing, probably an in the field repair.
Raptor Engineering do a steel version and a how to video so I'm off to watch that and then order one. Thanks for all your help. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
2nd Sep 2019 1:43pm |
Mo, SNAP!
We crossed in the post. Thanks 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
Click image to enlarge Here's one I prepared earlier Been in a few years now. Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
2nd Sep 2019 1:46pm |
