![]() | Home > Tdi > 300tdi loom with td5 wiper switch-info on differences |
TDi 300
![]() Click image to enlarge ![]() Click image to enlarge TD5 ![]() Click image to enlarge ![]() Click image to enlarge Last edited by dorsetsmith on 30th Aug 2019 8:07pm. Edited 1 time in total |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 490 ![]() ![]() ![]() |
Thanks, unfortunately the wires look like they should be the same colour, which I am sure I have matched, I will need to double check though, has anyone used td5 stalk and 300 loom, is there a difference?
The pins were there on the loom side and we got a plastic plug to match the stalk so that it’s fits together, it just won’t work apart from when pushing for water and it wipes. Any suggestions where to look? 2015 RRS Autobiography SDV6 1994 Def 90 300tdi |
Go through and check the wire point to point again
Finally got to look at this today, so a bit of info some of you may find useful one day in the future. 4 of the 6 cable colours between TD5 switch and 300tdi wiring are the same, the other two are different between plug and socket. Changing them two over sorted it all out.
We then found that the park position was with the wipers up instead of down. This was a turbo diesel wiper motor and TD5 cable and boxes, park switch was working correctly, but on the main drive cog there is a plastic bit and a metal bit, the plastic bit needed to be gently prised slightly off the metal holder and rotated 180 degrees. All sorted now 2015 RRS Autobiography SDV6 1994 Def 90 300tdi |
