Home > Technical > Is this amount of play normal
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Hi guys,
Just wanting to find out why I’ve got a pull away clonk...
Is this amount of half shaft play normal? It is the same both sides. Car is a 2001 td5 with 45k on the clock. Has only been off road on my holiday this summer along gravel tracks. Nothing crazy.
Post #788534 25th Aug 2019 12:09pm
landy andy
Potentially yes, but you aren’t testing/showing half shaft play. I assume you have just put handbrake on. So you are showing play in, drive flange to half shaft, halfshaft to diff, ring to pinion in diff, and two lots of UJ play.
But what you’ve got there initially looks norm.
Post #788535 25th Aug 2019 12:18pm
LandymanStefan
It’s a one piece shaft/flange and that movement is without the prop uj’s moving at all so I’m thinking it’s halfshaft to diff play?
Post #788545 25th Aug 2019 1:42pm
landy andy
I that case I would think the play to be the diff it’s self. You don’t really get much movement/wear in the half shaft to diff to be honest. You can always undo flange bolts and pull shaft out for a physical check, as any wear would be on shaft, not diff. The play in normal/standard with LR diffs.
With the wheels on the ground, and handbrake off, in neutral, how much can you turn the diff input flange.
Post #788556 25th Aug 2019 2:50pm
dailysleaze
I would say that play is pretty good for a Defender
Post #788585 25th Aug 2019 7:24pm
Retroanaconda
As above, that amount is nothing. If you're getting to 1/4 of a turn then start worrying.
Post #788654 26th Aug 2019 11:13am
LandymanStefan
Great, thanks chaps.
No valid excuse to upgrade to Ashcroft HD’s just yet Rolling Eyes
Post #788665 26th Aug 2019 12:40pm
