Home > Puma (Tdci) > Losing coolant
Timbo66
United Kingdom 2008 Defender 90 Puma 2.4 CSW Java Black
Losing coolant
Hi all,
I have an issue whereby my 2008 Puma is losing coolant and going into limp mode. Top it up and all runs fine. I've also noticed that I now have hot air blowing through some but not all of the vents. It has air conditioning that has recently been regassed.
Can't see any obvious leaks.
Any ideas anyone??
Thanks
Tim
Post #788518 25th Aug 2019 6:53am
williamthedog
Try changing the cap, known for leaking. Thumbs Up
Post #788519 25th Aug 2019 7:35am
landy andy
Investigation into the limp mode needs to be looked at as that’s not normal for water loss.
Get it plugged in will probably be your best bet.
Post #788523 25th Aug 2019 8:14am
Timbo66
Thanks for the responses.
I'm sure it is going into limp mode because the engine is over heating as it is fine once you top up the expansion tank. From what I read the engine does this to stop it from serious over heating.
I'll try a new cap, but it doesn't show any signs of water loss around it.
I can't understand why the cab is getting so hot through the air conditioning as it has had a new condenser and regas not long ago.
Post #788615 25th Aug 2019 10:51pm
NickMc
You’ve two options really here pressurise the system with a tester and look for leaks or a do a “sniff” test to check for a combustion leak. Is the water pump functioning?
Your air con system and “straight” engine are different systems. Although maybe if you’ve had work done on the air con they’ve disturbed a radiator hose or sensor near the condenser- again a pressure tester may produce a leak.
Post #788619 25th Aug 2019 11:56pm
