Home > Puma (Tdci) > 2.4 Puma Engine Knock Noise
george54321
Hi Folks.
I have been running my Defender 110 Puma since I bought it new in 2007.
Its been subject to all the recalls etc but in general I think it's the best moter i've ever had.
It's comming up to its second MOT so I thought it's time to get a workshop manual & start doing the servicing myself. "So far so Good".
I've read all the service reports attachet to the workshop manual & the special service bulletin below is a worry to me to say the least. The Puma engine has been around for some time so I would have expected such a basic problem to have been sorted before it ever got put in a Landrover.
Anybody out there had engine problems as described in the Bullitin.
SERVICE BULLETINS
SPECIAL SERVICE ACTIONS
Ref:- 2.4 Puma Engine Knock Noise
Models LD - Defender
Title 2.4 Puma Engine Knock Noise.
Last Modified 21-JUL-2008 09:44
Category Engine
Symptom 497000 Engine Noise
Content
Issue:
Heavy audible knocking heard on start up.
Cause:
On start up oil pressures can cause the
piston cooling jets, (PCJ), to latch into a
zero flow condition. Due to hysteresis effect
in design the jets do not unlatch until the
engine is warm and the oil pressures lower
again. During this time with no pressurized
oil jet flow to the lower pistons / cylinder
bores, overheat and scuff conditions /
damage can occur.
Action:
Replace the engine assy but ensure only
engines post serial # ELD00080707063602
are used.
This condition will not occur on vehicles
post assured Vin# 9A767162.
Engines post the info above are fitted with
modified PCJ internal springs and this issue
is now closed.
Post #78834 3rd Jul 2011 7:12pm
CRJ
Denmark 1991 Defender 90 200 Tdi ST Alpine White
I had some problems that I thought was connected to the service bulletin - everything mentioned here: http://www.defender2.net/forum/topic6656.html?highlight=
Regards
CRJ 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
90 200tdi 1991 - sold
88 Ser. 3 1977 200 TDI
110 CC 2003
Post #78836 3rd Jul 2011 7:23pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Yep ... mine was replaced under warranty at 2 weeks old, developed said 'knocking'.
No hassle or drama, had a spanking Disco to run around in whilst they changed engines. Cool Guns and Landrovers .... anything else is irrelevant.
Post #78837 3rd Jul 2011 7:24pm
CRJ
I have been told that the problem appeared early on affected engines - not years and several miles later.
Puma 130 - 08- sold
110 CC 2003
Post #78846 3rd Jul 2011 7:59pm
george54321
Hi folks.
Thanks for the info every little helps!
Keep smiling.
Thumbs Up
Post #79617 9th Jul 2011 3:34pm
