![]() | Home > Technical > Article on adding 2 stoke to your fuel |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4784 ![]() ![]() |
Here is an article on adding 2 stroke to your fuel. There is a question and answer section at the bottom.
https://www.baileysdiesel.com/on-highway/t...l-engines/ Nothing like resurrecting an old topic.... ![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Good spot. An eye for the little details Mr Holmes! I found it interesting regarding the explanation as to why only mineral oil should be used. I never knew why synthetic was a no no. 1982 88" 2.25 diesel
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6168 ![]() ![]() ![]() |
Lucky they didn't spell it semen's fuel system.....
Maybe you need a shot of that per tank? ![]() |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 ![]() ![]() |
/\ it's bad enough seeing all these electric charging points at service stations.....
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3600 ![]() ![]() ![]() |
![]() ![]() ![]() I'm sure if you do a search, this was argued to death about three or four years ago. The conclusive answer, there wasn't one ![]() |
I know this has been discussed as adnauseum but I just came across the article and thought it might be of interest. 1982 88" 2.25 diesel
Another article here:
Your 4X4 is not a lawnmower…The truth about tipping 2-stroke oil into diesel https://magazine.unsealed4x4.com.au/en_US/...art_1.html |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 588 ![]() ![]() ![]() |
2 stroke oil changes the sound of the engine because it changes the combustion temperature.
If you want to know, how to lubricate a modern engine, check this link https://www.biofuelsforum.com/threads/217-...Warranties |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5276 ![]() ![]() |
as we used to say on the 306 forum back in the day, just run it on veg
![]() joke a side, I did read a few lads used to put 2 stroke oil in the hdi tanks when they used to fill up. All it did was quiet down the injector tick. To me I rather leave a lone, if its not bust don't fix it. ![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
chalky Member Since: 09 May 2008 Location: Yorkshire Posts: 483 ![]() ![]() ![]() |
I ran this stuff in my D3 from 2009 to 2016, in that time it covered 160k miles !
Tesco were selling the Castrol Actevo off at £1.07 a litre which at that time was cheaper than fuel, as I only ever fill from empty to brim I poured a litre in at every fill. I bought hundreds of litres of the stuff in boxes and evenly distributed it about the D3 forum at meets and at the factory tours we used to do, it certainly quietened the engine from cold start in sub zero temps, despite all the panic at the time that car was passed on to a family member and it’s done nearly 210k miles . Nothing engine related in terms of issues or fuel system related. I’m still finding bottles of the stuff in the garage ! I haven’t used it In anything since the DPF applications and my current car is Petrol. DEFENDER XS CSW 08 TONGA GREEN |
