![]() | Home > Tdi > clutch issue |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 ![]() ![]() |
Possibly rust on the flywheel? It is not a Defender, it is a One_Ten
suboffroader Member Since: 19 Mar 2014 Location: leicestershire Posts: 18 ![]() ![]() ![]() |
i didn't find enough time over the weekend to attempt to bleed the system , however i did find the chance to roll under with a torch and what i did find was a fragment of metal roughly 15mm x 10mm x 3mm thick sitting in the wading plug hole, im guessing this is from one of the fingers of the pressure plate, is this a common failure of a pressure plate and would loosing a finger on the pressure plate cause my issue , im now begin to think the box is going to have to come out
Not heard of it happening before. So would guess it is not a common failure.
Sadly it sounds as though the box is going to have to come out. Not a joyous prospect and one I have to look forward to in the not too distant future. It is not a Defender, it is a One_Ten |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1679 ![]() ![]() ![]() |
Has the clutch got rusted in place, the fork got stuck and the extra pressure used punched the famous hole in it?
you normally get a solid pedal when the fork fails or a spring falls out. |
update:
Got round to bleeding the system. no improvement next step is to have the gearbox out to have a proper look, i'm suspecting pressure plate or clutch fork at fault, |
Update i dropped the gearbox at the weekend
the bearing had seen better days (it was that rough im sure it was barking) the pressure plate fingers had been pushed in some bent new clutch, pressure plate, bearing and fork ordered , also ordered a new slave cylinder as the boot disintegrated |
