![]() | Home > Puma (Tdci) > Servicing and Fuel Related Info for a 2009 Defender PUMA... |
RobM Member Since: 06 Jul 2015 Location: Brisbane Posts: 55 ![]() ![]() ![]() |
Guys... Hoping to gain some info from Defender 2.4ltr PUMA owners' experiences here...
1. I've got a '09 Puma 110 that I want to do the Oil/Filter change myself... The question is how often do u need to replace the drain plug with a new one or can u simply buy the O'Rings and reuse the plug? What about using a Copper Washer instead? 2. Looks like I also need to replace my worn out suspension bushes (front radius arms, etc) - Which would be better > SuperPro or Rubber? (i've been running SuperPro on my old Defender for a while now w/o issues but I've heard people say rubber is better....) 3. Fuel Filtering - I had fuel problems on our recent outback trip and it got me thinking if there is a better fuel filtering system (ie: replace the existing with something better with a built-in primer) or install an aux fuel filter somewhere that also has a built-in primer - What are peoples' thoughts? 4. How do u disconnect the Fuel Lines from the Factory Fuel Filter? Do u need a special Tool at all? Can u buy these fuel line hose fittings for Spares? 5. Thinking about replacing the factory std fuel tank with an LR Fuel Tank. I've also got a Factory Towbar and Folding Step fitted + I also have the Aux Inner Guard Fuel Tank installed - Is there an Aftermarket Replacement LR Tank that I can source that will still allow me to utilise the Inner Gaurd Aux Fuel Tank + keep my Factory Towbar and Folding Step? Cheers..... Rob 1995 Defender Tdi 110Wgn 2010 Defender PUMA 110Wgn TRIPS: Meanderingdownunder WikiLoc Trips |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3650 ![]() ![]() ![]() |
Hi Rob
if you do a search most of the issues you raise have been covered before. regards the drain plug for the sump dont use britpart, genuine ford part from ford is much cheaper than from Land Rover and OEM quality DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
