Home > Td5 > Td5 Clutchfix hd1 clutch
Defender Fun
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
Hi
Has anyone had a clutchfix hd1 clutch fitted to their td5? As I have had one fitted to my 2001 td5 Tomb raider, however it has a very very heavy clutch. Everything was changed, fork, release bearing, push rod and slave cylinder as well as the complete clutch. I believe only the master cylinder wasn’t changed as this had been done recently.
Can anyone help
Kind regards [/s]
Post #787408 17th Aug 2019 9:06pm
LizzyTD5
England 2004 Defender 90 2.5 TD X-Tech LE Zambezi Silver
Just changed mine exact same procedure and all good. Fractionally heavier but otherwise been ok for circa 500miles. Guys at Clutchfix helpful so give them a call.
Post #787923 20th Aug 2019 6:11pm
bankz5152
Their clutches are just very heavy as standard. I asked about this before going for LOF the reply was "fit a red booster" Instagram @defender_ventures
Empire Tuning - Agent
Post #787928 20th Aug 2019 6:23pm
