![]() | Home > Puma (Tdci) > Comma oil |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4255 ![]() ![]() ![]() |
I think that is fine, meets the Ford spec for the Puma 2.4 (...913B) 2007 110 TDCi Station Wagon XS
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Yes, good oil- used it for years, I buy it in the 20l drums and keep one in the house- works out cheaper in the long run. Can use it in td5’s too.
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 756 ![]() ![]() ![]() |
This is the same stuff being supplied by Advanced Factors, ja?
Paul55 Member Since: 03 Feb 2009 Location: Somewhere in my head! Posts: 514 ![]() ![]() ![]() |
Have a word with the guy at Opie oils I think they still do Def2 discount
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4762 ![]() ![]() |
Yep, fire away I use it and will continue to do so. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Jimmy B Member Since: 11 Nov 2017 Location: Cumbria Posts: 51 ![]() ![]() |
Brilliant, thanks for all the replies
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 748 ![]() ![]() ![]() |
Comma do a trade line. Exactly the same but cheaper. Ask wherever you buy it as saves a few quid.
Dobby Member Since: 23 May 2012 Location: East Seaxe Posts: 187 ![]() |
Blimey! How does the other half feel about that? I suppose it depends where you keep it. Wardrobe might not go down too well, nor would the fridge. SWMBO Mrs Dobbs would do her nut if she found an oil drum abooot the hoose. |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5117 ![]() ![]() ![]() |
add 'def2' code for Opie Oil 10% discount
![]() http://www.youtube.com/user/conwy1 |
In the garage and a 1L bottle in each motor ![]() ![]() ![]() |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4800 ![]() ![]() ![]() |
I guess you could always fill the bath with it
![]() 2008 SVX 90 2000 XS TD5 90 |
I prefer to bathe in EP90....get it in your nostrils :
Just noticed this on offer for about £18 in GSF at the minute. 2007 110 TDCi Station Wagon XS
lonewolf Member Since: 23 Oct 2013 Location: North East England Posts: 210 ![]() ![]() ![]() |
I am currently using it, it’s fine. Bought from Opie, after discussion as to whether it was correct to use on a 2.4 tdci.
All they said was that it meets the specification required for my engine and would be fine to use. |
