Home > Maintenance & Modifications > Reverse light to rear speaker panel
Does anyone know if there is an existing usable cable entry behind the speaker panel directly above the reverse light on the Puma? I tend to think not, and only on the other side above the fog light instead. I can always check taking the speaker out but wondered if anyone knew off the top of their head?
If not, I’ll just have to run over to the other side and up which will likely be the case I think.
Thank you TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #786467 12th Aug 2019 2:34pm
rallysteve
Should be as it is where the LH tail light and brake light wiring passes through.
Post #786477 12th Aug 2019 2:58pm
Yes, definitely. You can see them in this pic of some of my additional wiring:
 Darren
Post #786497 12th Aug 2019 6:03pm
Awesome, thank you both of you.
You never know with LR and their wisdom if they'd have brought the feeds in one side, up and over and back down.
I rarely ever access that side so that's very helpful indeed. Mr. Green
At some point I need to get out the seized screws holding the plastic protective panel up underneath too.
You guessed it, seized solid and the cross head on the screw will slip. Rolling Eyes
I'd have thought I might have to either get some kind of extractor bit for these or carefully grind the screw heads off so that the panel can come off and remove the rest of the thread with pliers.
I've tried getting behind to try and wind them out but they are steadfast holding on there. Rolling Eyes
On of the reasons I try an avoid using screws with such a head.
I can probably reach up behind anyway for feeeding the reverse feed though, but these sort of things are a real pain.
Ideally the fuel tank breather needs to go up behind there as well.
Thumbs Up TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #786503 12th Aug 2019 6:31pm
