Home > Td5 > Extra relay under hood |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
That does not look factory to me. Can you trace the cable as I think it is a boom slang loom. I gives more voltage to the lights. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
11th Aug 2019 5:14pm |
Ndamico Member Since: 03 Apr 2019 Location: Canada Posts: 52 |
of the 4 wires:
1 black ground to engine 2 red connect to the alternator battery post 1 connects to the factory wiring loom under the intake manifold. you can see it in the picture. i guess the question is what terminal on the OEM harness is it connected to? i see no connection to the headlights. 04 110 TD5 |
11th Aug 2019 5:32pm |
here is the wire in question. i've circled it in red
Click image to enlarge 04 110 TD5 |
11th Aug 2019 5:37pm |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 |
Disconnecting the earth wire from the relay will disable it. Try doing that and see what doesn't work
11th Aug 2019 5:46pm |
here is the wire in question. wire colours
the wire looks to be brown with a red stripe. could be 50/50 brown and red. im almost thinking is has to do with glow plugs as the other wires next to it coming from the loom go to the glow plugs 04 110 TD5
11th Aug 2019 5:51pm |
wire from starter motor rely starter motor coil Brown - Red 3.0mm
Click image to enlarge |
11th Aug 2019 6:07pm |
so does that mean someone bypassed the starter relay? 04 110 TD5
11th Aug 2019 6:21pm |
black wire go to one side coil how are the other wire connect to the relay |
11th Aug 2019 6:38pm |
So if I want to reconnect this to the original relay inside the truck, where would I connect it to?
04 110 TD5 |
11th Aug 2019 10:05pm |
I disconnected the ground from the relay and the starter doesn't run so that's it. What do I do to put it back to stock? 04 110 TD5
12th Aug 2019 12:01am |
Click image to enlarge Click image to enlarge Last edited by dorsetsmith on 12th Aug 2019 7:16am. Edited 1 time in total |
12th Aug 2019 6:59am |
Hi,
I'm wondering where the wire in the engine compartment that is currently connected to the aftermarket relay is meant to go? 04 110 TD5 |
12th Aug 2019 7:03am |
Link 5 60amp under drivers seat fuse box ( NW ) brown- white wire 4.0mm to Relay two centre fuse Box from Left side (30)
(NR) brown - Red wire 3.0 - 4.0mm from relay two centre box (87) to starter motor (C0179-1) Click image to enlarge (WR) white - Red wire from ignition switch to relay two centre box (86) coil (BO) Black - orange wire from Alarm ECU pin 10 green plug C0057 to relay centre box (85) coil Click image to enlarge |
12th Aug 2019 8:04am |
