Home > Td5 > weird leak
Ndamico
Canada 2004 Defender 110 Td5 CSW Alpine White
weird leak
i have a leak but i can't figure out what it is. it sprays on the side of the enginre compartment when i'm running but i can't find anything wet under the bonnet. i've cleaned the area and it comes back. its so thin i can't tell what type of fluid it is. any suggestions?
Post #786293 11th Aug 2019 3:50pm
bankz5152
What side?
Pics would help Instagram @defender_ventures
Empire Tuning - Agent
Post #786296 11th Aug 2019 4:00pm
Ndamico
Post #786299 11th Aug 2019 4:01pm
Ndamico
bankz5152 wrote:
What side?
Pics would help
sorry, i uploaded but forgot to actually post them. i just did. its the right side of the engine compartment.
Post #786300 11th Aug 2019 4:02pm
bankz5152
Most likely spilling for the PAS reservoir when on an incline or very hot. It happens. The breather hole for the PAS is at the back and does spill there Instagram @defender_ventures
Post #786301 11th Aug 2019 4:04pm
Ndamico
this hole? its pointing directly at the front bumper and doesn't appear to be leaking. or is there another vent hole?
Post #786305 11th Aug 2019 4:38pm
geobloke
Re: weird leak
Is it oil, diesel or coolant?
Post #786308 11th Aug 2019 4:48pm
bankz5152
That is the one im on about yes. Unsure if there are two
Could be a leak from the pas anyway, id check Instagram @defender_ventures
Post #786309 11th Aug 2019 4:51pm
Ndamico
i can't tell. its is a bit slick to the touch but i can't detect an odor. i clean the area up and it comes back in a day. everything on the side of the motor seems dry.
Post #786312 11th Aug 2019 4:55pm
Ndamico
i'll clean and wrap the res in a rag to see if it comes back.
Post #786313 11th Aug 2019 4:56pm
roel
There is a hp diesel hose along the engine runs from the back to the front. I had a leak there last month. But as it is a 4 bar pressure line I think it would be more visible. At least mine left some some traces for about 10 km that you still could follow a few days later. Twisted Evil Roel
2003 90 Td5 (2009-now)
Post #786315 11th Aug 2019 5:09pm
landy andy
Have you checked the pipework from the engine breather.
Post #786518 12th Aug 2019 8:33pm
rallysteve
If it is coolant, check the fuel cooler under the inlet manifold. Mine used to leak only when the engine was warm. If it is PAS fluid, check the union at the front of the engine near the front most inlet manifold bolt. 02' 110 TD5 Double Cab Rebuild Thread
Post #786521 12th Aug 2019 8:44pm
