Home > Puma (Tdci) > 2010 2.4 tdci 90 Rear Disc change help required. |
B4Lamb Member Since: 21 Mar 2015 Location: Abergavenny, Wales Posts: 233 |
Thank you all above for the excellent information and advice.
I'll definitely convert to the two nut solution if I find it's not been done already. As it's been said it's a no brainer. Why on earth did Landrover change to a staked nut I've no idea. It's not like the hub and discs will never need any maintenance. The engineer probably received a bonus for saving 20p per car. The caliper bolts are definitely 12 point and I do have a set of these socketa. The main reasons for this job is to replace the pitted and scored disks and to fit new calipers as I have corrosion and sticking pistons. "You are never to old to learn something new" |
4th Aug 2019 12:45pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1662 |
I normally re-pack the bearings and stick a hub seal in when I do them, for how little it costs.
4th Aug 2019 2:53pm |
Yes definitely agree. While it's all apart. Good idea "You are never to old to learn something new"
4th Aug 2019 3:10pm |
lonewolf Member Since: 23 Oct 2013 Location: North East England Posts: 210 |
I agree with ^ grease repack and new seal, doesn’t cost the earth.
Thanks to all who replied to my original post.....cheers folks. |
6th Aug 2019 1:36pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8155 |
You don't need circlip pliers, leave the shaft on the drive member as they will be two piece. And just remove both together. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
6th Aug 2019 8:20pm |
