![]() | Home > Technical > 13pin Towing Socket |
Should be P&P if you buy the original LR harness....
https://www.defender2.net/gallery/albums/u...agrams.pdf Here the schematics and the connector C0718 is present on the car (rear RH wheelarc, under the splash guard, same as the lower rear RH lights) ![]() Click image to enlarge Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2217 ![]() ![]() ![]() |
perfect, thats what i was hoping
thank you |
DG123 Member Since: 29 Aug 2015 Location: North West Posts: 136 ![]() ![]() ![]() |
Hi - plug-in for 13 pin electrics only goes as far a lights/indicators. It gives you the equivalent of the black 12N 7 pin plug. The rest of the electrics (i.e. the functionality of the old 7-pin 12S connector) including permanent and switched lives, split charge relay and reversing light takes a bit more faffing.
![]() Click image to enlarge ![]() Click image to enlarge It’s all well documented in the genuine LR electrics fitting kit, and many have taken the feeds for these from the rear of the vehicle. I still haven’t got around to fitting the ‘12S’ part of mine. The genuine kit LR005919 for a 2012 Puma has a really well sealed 13 pin plug that hasn’t given any issues compared to other vehicles that have had generic ones fitted by local tow bar places FWIW I fitted the 13 pin socket in the rear crossmember (with rivinuts). It’s then only a few bolts to take off the towbar and the electrics stay put. Also less chance of damage. Good luck 2012 110 XS SW Orkney Grey 2003 D2 Td5 Black [SOLD] |
Cheers for the extra info, have just done the relay / extra wiring on a different vehicle so not phased by that side
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6654 ![]() ![]() ![]() |
Only the ignition feed for the socket is a “faff” involving the relay. Everything else is done by plugging in.
