Home > Puma (Tdci) > Load liner
22900013A
Load liner
Is there any kind of matting or something available for the back of a 110 USW? I don't want the seatboxes getting all scratched up and damaged, so is there any way to protect them without having to spend a fortune? 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #78303 28th Jun 2011 10:47pm
Zagato
Stable matting 6X5 £38 from agricutural/equine suppliers Thumbs Up It's quite heavy though!
I would also be interested if someone has a source of bigger lighter stuff!
Post #78311 29th Jun 2011 6:39am
JASPERTHEHORSE
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Orkney Grey
Spray on speedlinder!!!
Had it in the back of our 110 DC and it was awesome.
Most of my HT customers get it done by a guy locally up our way called KTD in Gateshead (Im sure there are franchises nationwide). I think on average its £250 - £300 done.
It really is mega impressive stuff, ultra tough, and offers good sound deadening properties as well.
Post #78325 29th Jun 2011 8:58am
22900013A
I was hoping for a slightly cheaper solution to be honest... Confused 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #78378 29th Jun 2011 5:32pm
Zagato
Most people board the rear or vans out of course, cheap and easy to do Thumbs Up
Post #78380 29th Jun 2011 5:43pm
mattlab
England 2009 Defender 110 Puma 2.4 USW Galway Green
have just done mine, went to my local rubber stockist called walker rubber and plastics and bought some ribbed rubber matting which was 1.2mtr x 1.2 mtr x 3mm thick and i got 2 lenghs of that which they call flat fluted matting and it was £44.92 + vat. i fitted it so the the ribs ran front to back so they follow the curve of the wheel box. i did the tub first and let it lay over the plastic cover for the seat brackets and came up the side of the wheel boxes so that you get a nice water tight tub, then i did the wheel boxes and over lapped it down the side of the tub rubber and fixed it with spray glue. looks like a factory job, just the job for my dogs as the carpet was starting to stink, you could do the whole job out of 1 piece but i found doing it in 3 bits was far easier, i covered over my tie downs as i dont use them and i wanted it water tight so i could hose it out if i need to, i`ll see if i can work out how to download a picture in the next couple of days, hope this helps. LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE
Post #78383 29th Jun 2011 6:04pm
22900013A
I've been thinking of that, as I'd quite like some shelves or storage boxes for tie-down straps etc, and take the toolbox off my trailer. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #78384 29th Jun 2011 6:04pm
JSG
[tongueincheekmode]
How about chequerplate?
[/tongueincheekmode]
Whistle Whistle John
2011 Tdci 110 CSW XS
Post #78396 29th Jun 2011 7:19pm
22900013A
JSG wrote:
[tongueincheekmode]
Whistle Whistle
Wash thah mouth aht wi soap! (As my mother used to say Wink) 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #78400 29th Jun 2011 7:26pm
BigMike
chequer plate? Laughing this isn't difflock.com you know Laughing
Post #78401 29th Jun 2011 7:31pm
JSG
Even with [tongueincheekmode] my sharp wit and humour is wasted here .......
I know how much 22900013A hate chequerplate so I thought I'd try and get him to consider the other side Mr. Green John
Post #78406 29th Jun 2011 7:40pm
22900013A
Thats a point, I could use the smooth side! Wink
Other option is not to put anything...at all...in the back.
Dan. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #78408 29th Jun 2011 7:46pm
RFT
United Kingdom 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
Ribbed rubber matting available from Machine Mart, I use 6mm thick for tub floor, would need thinner to shape around seat boxes. 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #78445 30th Jun 2011 12:23am
Zagato
http://www.machinemart.co.uk/shop/search/f...any/page/1 Something out of that lot should suit Dan, thanks also RFT Thumbs Up
Post #78468 30th Jun 2011 7:54am
