Home > Maintenance & Modifications > Swapping 4-pin rear differential gear to the front
Arthur Mak
Hong Kong 2012 Defender 110 Puma 2.2 SW Orkney Grey
Brothers, I am going to install an Ashcroft Air Locker to the rear axle of my Puma 110.
At the same time, I wonder could I swap the orginal 4-pin rear differential gear to the front (which is orginally 2-pin at the front). Is it feasible?
When I checked the diagram at LRworkshop, I noted that there was a "front differential gear housing" whihc does not exist at the rear axle, did the swapping job easy or need a lot of parts to buy?
Thank you very much.
Post #782830 24th Jul 2019 8:42am
No. A Rover diff can be fitted in a P38 housing but not vice versa.
Post #782835 24th Jul 2019 9:19am
jst
Post the fitting of the p38 rear diff casing, td5s 110s inwards, it's not a straight forward swap. I was under the impression You could build the centre into a std rover diff though. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #782867 24th Jul 2019 11:11am
You can certainly build a Rover centre into a P38 pinion housing, all you need is a spacer between the crownwheel and flange (which is why the same ATB or locker fits either).
To go the other way you'd need significant machining and I don't think there's enough material on the P38 diff for this.
You could modify the axle case and propshaft and fit the complete assembly, but it would be a bit daft to fit an interior short-nose pinion housing in place of a long-nose.
Best option is an Ashcroft ATB.
Post #782871 24th Jul 2019 11:33am
jst
Understood.
Best option surely is the the low pinion hypoid air locker! For off roading anyway! Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #782987 24th Jul 2019 9:43pm
Arthur Mak
Maybe this picture can better show my question, can I use the red part to replace the blue part?
As I am going to install a airlocker in the rear axle, the whole red part will be replaced.
Post #782996 25th Jul 2019 2:11am
As I said above, tthe simple answer is that ig cannot be done.
Your rear differential is a P38 type, (or "short nose" diff). Your front differential assembly is a Rover type (or "long nose" diff). It is possible to fit the differential from your front axle into your rear axle pinion housing, but it is difficult (albeit not totally impossible) to fit the differential from the rear axle into the front pinion housing.
Although generally very similar in overall dimensions, the crownwheel on the P38-type diff is closer to the axis of the pinion by about 5mm. To fit the P38 diff into the Rover pinion housing you would have to do a significant amount of machining to the P38 diff carrier, making it generally impractical.
T!G UP on this forum has done it. These photos in his gallery show what needs to be done:-
https://www.defender2.net/gallery/thumbnails.php?album=967
Post #783017 25th Jul 2019 7:41am
Merlin
Can I fit a 4 pin diff to the front of a 2008 Defender as a direct replacement?
Post #803167 22nd Nov 2019 12:55pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Post #803172 22nd Nov 2019 1:36pm
Merlin
Yes thanks. FYI they are on a 2 week turn round on builds. Peter.
Post #803176 22nd Nov 2019 2:19pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Hi,
It might be worth trying Winchester Gears in Rotherham- they tend to have a reasonable amount of stock and I can vouch for the quality of their work being spot on.
Regards
Chris
Post #803207 22nd Nov 2019 5:06pm
