Home > Maintenance & Modifications > Water Leak behind Brake Lights
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
The rear of my Defender has a leak when it rains, it appears to be running down the rear corner from the gutter and then coming in behind the brake lights, creating puddles in the rear corners where the wiring covers for the lights are.
I've used Sikaflex for all of the body seams but reluctant to permanently glue the light bodies to the vehicle. Has anyone used thin gauge closed cell neoprene? I was thinking of cutting circular gaskets and sticking them onto the rear of the light units with a central hole for the wiring to run through or is there a better solution?
Thanks, Harry
https://www.ebay.co.uk/itm/Adhesive-Backed...MMKgFehFqQ 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #782690 23rd Jul 2019 7:44am
landy andy
The rear lights should have thin neoprene gaskets as standard.
Post #782691 23rd Jul 2019 7:47am
Harry.O
Thanks Andy, the lights have been swapped for LED units by the previous owner and there are no gaskets behind so guess that's the cause of the problem. Thumbs Up 2005 Td5 110 Hardtop
Post #782718 23rd Jul 2019 12:31pm
When I fitted NAS lights to mine, I made gaskets with some sticky-back neoprene:
 Darren
Post #782720 23rd Jul 2019 12:50pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
I had the same problem with mine and went down the dum dum route, worked well so far, have tried to source a part number for the neoprene gaskets but no luck so far, unless anybody has the part number handy? Cogito ergo sum
Post #782721 23rd Jul 2019 1:17pm
Harry.O
Thanks guys, I did a quick search to see if there was an off-the-shelf solution but couldn't find anything so ordered some sticky neoprene in 1.5mm thickness and will make up some gaskets like LRA did Very Happy 2005 Td5 110 Hardtop
Post #782722 23rd Jul 2019 1:27pm
ericvv
Not sure which LED lights you have, but if it would happen to be 95 mm Le Perei lamps, you can order their ready to use gaskets separately from DunBri group. Guess can be used on other brands 95 mm plinths/lamps also. Link below.
Eric
https://www.dunbrionline.com/Brands/Perei-...ps-320SL9G You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #782725 23rd Jul 2019 1:58pm
