Home > Puma (Tdci) > Knock behind dash |
Roba71 Member Since: 07 Jun 2019 Location: Rangiora Posts: 16 |
Ive got what sounds like a coin or nut rolling from side to side, when going around corners in the radio area at the moment.
Theres never a dull or quiet moment in a Landy im finding |
17th Jul 2019 11:38pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4709 |
I would agree with the bonnet hinge inserts. Lift up your bonnet and if you can move it the inserts are worn. You could drive the vehicle with the bonnet removed and this will confirm for sure if the bonnet hinge bushes are worn. 1982 88" 2.25 diesel
22nd Jul 2019 5:11pm |
sweatysock Member Since: 17 Jul 2011 Location: Warwickshire Posts: 283 |
Thanks but already driven with bonnet off....ruled that out Sweatysock
------------- 110 CSW TDCI (Puma) 2007 |
22nd Jul 2019 7:42pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3708 |
Check that the bolts holding the floor panels are tight. 130's have feeling's as well you know
22nd Jul 2019 7:48pm |
I now need to add i've got what sounds like a unmetallic creak coming from the steering wheel area, to go with the coin like noise rolling around the radio area.
I brought this 110 completely creak and rattle free 6 weeks ago, the previous owner must of emptied several cans of "creak free" over the whole vehicle |
23rd Jul 2019 6:10am |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 456 |
Agreed, I tightened up a little bolt that is quite hidden, under the mats and sort of under where the handbrake is IIRC, that cured one of my little rattles! Def put a bit of lube on the bonet hinge bushes too, that will work. Cheers |
23rd Jul 2019 9:10am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20453 |
Front upper damper bushes is possible No Guts, No Glory.
23rd Jul 2019 5:06pm |
MartyDiBergi Member Since: 23 Apr 2021 Location: England Posts: 8 |
I have got a creak / knock coming from somewhere in the steering column. It’s only noticeable at low speed on a smooth road and it’s worse when it’s warm. I can feel it through the steering wheel. If I grab the steering wheel and put pressure on it I can make the sound happen but there does not seem to be any play in the column, it’s more like something is rubbing somewhere. Most bushes have been replaced and the problem is still there. Could it be a sign of a bad steering damper? What is making contact with the steering column behind the dash? Thanks! |
23rd Apr 2021 10:04pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 666 |
If you can't find anything obvious, I would suggest replacing the lower steering shaft. It has three joints in it that can cause a range of noises.
24th Apr 2021 7:18am |
Thanks, I will investigate that.
25th Apr 2021 5:31pm |
